I have a Manrack without the rotopax and I ended up having to weld 1 inch plates from side to side at the front and rear to mount my pelican case. In hindsite I should have gotten the rotopax mount Manrack. I have a rotopax mount rack on my other bike and it works perfect to mount the pelican case. The added bonus is you can mount a rotopax and then put a soft bag above it as an option for longer trips or camping. A couple of SS bolts and wing nuts or thumb screws and it's secure, but easy to swap out.
I had delusions of making a slide lock removable mount for the case on the TW with the Manrack and after making it, i realized how useless it was. So I scrapped all that time and effort and welded the plates on for a bolt on process. But again, after all was said and done, I should have ordered the rotopax mount, bolted it down and not wasted 3 days and buying all the extra crap. Had I gone the rotopax mount, I could have easily switched the different sized boxes and my rotopax tanks from bike to bike, but sometimes i have to make things more difficult than they need to be. [emoji37]
Also the cases from Monoprice or SKB are equal quality to pelican at a much lower cost. I think Monoprice has 10-20% off this weekend too.
The gap may or may not exist depending on the size of the case used and where it's feet are. If it's a larger case the feet will be outside of the perimeter of the rack.
The rotopax mount is just a circle with 4 bolt holes. It's built to accept a rotopax latch which holds the tanks. So all you need bolts, nuts and nylon spacers. You can use wing nuts for a tool free removal or nylock nuts for a more secure mount. I prefer stainless and use SS bolts exclusively for accessory mounting.
Get some nylon spacers at the hardware store, something like 1/4 to 3/8 thick and sized for your bolts ( which for a rotopax are 5/16 I believe )
Spacers can be found at an Ace or True value hardware or a local real hardware store ( maybe lowes too ) but I buy all my hardware from McMaster Carr and Grainger. You can always buy 1 inch nylon spacers and cut them down to the exact length you want.
I would not use wood.
I use spacers like pictured below frequently for projects
When installing the case, think about mounting it just far enough back to still be able to remove the seat. Also I prefer the latches forward ( most rear boxes open from the back ) but I find it much more convenient to be able to open the box while standing beside the bike than walking around back to open the box.
I still had to empty the case to get to the knobs.
I ended up using the case bolted to the mounting plate (leftover from another motorcycle), then using the velcro or nylon ties to attach it to the rack.
I wanted to be able to remove the case without having to empty the contents.
In this instance, the case prevented the seat from being removed.
"How does the Pressure Equalization (Purge) Valve work?
The Pressure Equalization Valve (Purge Valve) is a simple device. It consists of a housing with a hole through it that is covered with a thin Gore-Tex® membrane. According to the GoreTM tech sheet: “The microporous expanded polytetraflouroethylene (ePTFE) membrane continuously allows the free passage of gases and vapours, equalizing the pressure differential between the enclosure and ambient before it builds to the point that a seal is compromised. Water, dust and dirt are repelled by the hydrophobic membrane, thereby protecting expensive and sensitive electronics”.
Here's is the Pelican 1400 case all mounted up...I have the case far back enough so The seat can be removed with no problem
Love how it looks on the bike and now I can bring along a couple bottles of water,lunch and some other stuff so I dont have to stuff my pockets anymore
I also ordered a 4 pack of the bungie buddies for the top
thanks...used some oak 1" thick to make a riser plate. I used some stainless brackets I found at lowes to hold the oak wood plate to the rack. Then used sheet metal screw and fender washers through the inside of the case into the oak plate. Solid as can be and quiet....about time I got off my my azz and did it.
Getting ready so I can do some fall rides,wanna do the pine barrens also
Now im looking at the Garmin oregon 700 gps
Gonna put one on layaway at walmart
Im probably gonna do a fuel cylinder mount also since I have stock gas tank
One item I rarely see addressed by those who use hard cases is how to keep contents from rattling around.
Without naming any names I can attest that a burst can of oily tuna fish at the beginning of a week long off-road adventure in hot weather doesn't do the rest of the box's contents any good.
For less than 100% load-outs I would suggest something like these tile sponges to take up excess room and provide padding. I got a bag of 6 or so from Home Depot for about a buck a sponge.
Got the bungee buddies mounted up today on the pelican 1400
Related Threads
TW200 Forum
532.4K posts
23.4K members
Since 2010
