Project Black Widow - Page 2
Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 201
Like Tree684Likes
Thread: Project Black Widow
  1. #11
    Jun 2014
    Bel Air Maryland
    3,282
    Can someone tell me what's involved in getting a title for this bike. The original owner apparently is from PA and had lost it.
  2. #12
    Sep 2014
    Mamaroneck, NY
    1,857
    MAybe Vermont?
    Quote Originally Posted by TopPredator View Post
  3. #13
    Jun 2014
    Bel Air Maryland
    3,282
    Well I troubleshot the BW today she has a few problems. The owner told me that the starter didn't work so I took it off and tested it. It's spins off the bike but it don't spin when installed. The relay clicks so I unhooked the positive lead on the starter and hooked my jump Box directly to the starter. Something froze up inside keeping it from spinning. He must have also kicked a tooth off the kick starter gear because I have to keep pushing down on the kick starter to get it to engage.
    . Looks like my winter project may teach me something about motorcycles when I'm done.
    I'm glad I got these bikes for a song.
  5. #14
    Jun 2014
    Bel Air Maryland
    3,282
    It's Alive!!! The kid painted the header pipe and muffler with non heat paint. When I first got it started it was smoking like a fright train right at the cylinder head. I didn't know what the hell was going on at first but as the paint burned off along the pipe I had to laugh.
    The original starter didn't work and seemed to be froze up. It worked off the bike so I pulled the left side engine cover and inspected the gears. All the gears were good so while I was in there I replaced all three oil seals and gasket. Changed the oil and filter then squirted gas in the spark plug hole. It fired up but I believe it could use some serious carb work. The RPM keep changing from fast then slow and is popping. I'm going to adjust the valve lash next.
    You will get a kick out of these pictures
  6. #15
    12,804
    "They asked me how I knew
    My true love was true
    I of course replied
    Something here inside
    Can not be denied
    They, said some day you'll find
    All who love are blind
    When you heart's on fire
    You must realize
    Smoke gets in your eyes" - the Platters
    -Luv the pics of the Great Paint Burn-off!
    The '89's always on front turn signals might just be the marker lights, running lights, parking lights or whatever Yamaha calls the second filament in the front turn signal housings.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  7. #16
    Jun 2014
    Bel Air Maryland
    3,282
    I of course replied
    Can not be denied
    You must realize
    Excellent Lyrics Fred and you are correct on the front marker/turn signal lights. What threw me off is a bad or weak turn signal relay but I didn't realize it until I noticed there were three wires going to the front lights and only two going to the rear.
    I'm making progress and I'm getting together a grocery list of parts that are MIA from my donor bikes. I couldn't imagine the cost of fixing up a basket case bike without donors.
  8. #17
    Jun 2014
    Bel Air Maryland
    3,282
    I tell you what... if I see a guy on the forum who wants to go cheap and buy an old TW. I'm going to let them know there's problems at every turn...if I didn't have donor bikes this project could get expensive quick. I'm glad I have a good running bike and this is just something to play with and learn motorcycle repairs.
    The threads are damaged on the throttle cables. One problem after another but I'm enjoying it
  9. #18
    Jun 2014
    Bel Air Maryland
    3,282
    I'm picking away on the BW... I broke down the rear wheel so I could inspect the rim. It's a tad rusty in spots so I wire brushed it and applied OSPHO tomorrow I will paint it and replace the tire and tube. I think the1988 tire and has seen better days. I sanded the break pads and hub. I think that should just about do for the rear wheel.
    Hello New Members. Hidden Content Please update in (Settings) (Edit Profile) (Location)where you are from. The best part of our Forum is meeting new members.
    TW 2006 Ruth
    TW 1988 Black Widow.
    Rick
  10. #19
    Jun 2014
    Bel Air Maryland
    3,282
    I went to war on this wheel and it came down cutting the bands with a pair of Craftsman diagonal pliers. GO TO WAR that was a bitch.
    War Tools
    This is what a 1992 wheel looks like after years of sitting outside.
    It's going to take some serious grinding the clean this wheel up.
    TW 2006 Ruth
    Rick
  11. #20
    Jun 2014
    Bel Air Maryland
    3,282
    The best part it has a 65 tooth sprocket
    I'm going to mount my 2006 use tire on it and climb a tree.
    TW 2006 Ruth
    Rick
  1. Black Widow TW200 on eBay - not my bike
    By craig0ry in forum TW200 Classifieds
    Last Post: 08-05-2016, 09:51 AM
  2. 1988 Black Widow ?
    By seabee591 in forum General Discussion
    Last Post: 04-13-2016, 10:52 AM
  3. Black widow January ride!
    By evan in forum Trails, Off-road, and Adventure Riding
    Last Post: 01-25-2015, 10:15 AM
  4. Mr Gizmo's/Black widow ride in Paradise!
    Last Post: 07-10-2012, 09:09 AM
  5. Black widow rides again!
    Last Post: 05-29-2012, 07:38 PM
