Wal Mart $30 YTZ7S Battery
Results 1 to 9 of 9
Like Tree41Likes
  • 8 Post By Mattwings
  • 4 Post By jtomelliott49
  • 5 Post By Xracer
  • 6 Post By wmgeorge
  • 4 Post By mrlmd
  • 3 Post By wmgeorge
  • 5 Post By Mattwings
  • 3 Post By socalnative
  • 3 Post By Mattwings
Thread: Wal Mart $30 YTZ7S Battery
    Mar 2015
    Northville, MI
    496
    My $30 (delivered with tax) Wal Mart battery came in today. I installed it, with the help of some hi density foam tape (worked ok, may look for a more sturdy solution after trying this out for a while). It is definetly smaller and a bit lighter. The qulaity seemed decent, easy adaptation of the stock connection and came fully charged. I verified by sticking it on a charger with voltage detection and AGM charge mode (2AMP). The bike started easilly and the lights and signals appeared very bright. I stopped and started a few times, let it run until it stalled (I try and run the bowl dry every time in the winter, even with treated fuel). I will report if I have any issues with dependabilty or capacity.
    2002 TW200
    1998 DR350
    1996 KDX 200
    Sep 2012
    Wichita, KS
    1,532
    I love a good battery thread. I seem to have problems with some of the batteries I have purchased. lol
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    Senior Member Xracer's Avatar
    Florida
    2,816
    I've had better luck with Wal-Mart battery's than the more expensive brands. Surprised me too!
    Member wmgeorge's Avatar
    Feb 2017
    Ankeny, IA
    57
    Quote Originally Posted by Xracer View Post
    At one time they were rated by Consumers Reports as a Best Buy. Since then that is about all I purchase. Warranty everywhere.
    Retired guy Central Iowa, Lots of Hobby's
    Senior Member mrlmd's Avatar
    832
    Again. that's a 6 amp-hr battery, smaller in capacity than what's recommended. The other one in your pic is 8 AH. Hopefully it will work for you if your bike starts quickly every time, but if it takes many attempts to start, for whatever reason (like when it's cold for instance), you might have a dead battery much earlier than with the higher capacity one. Like everything else, you get what you pay for, and smaller isn't always better.
    Feb 2017
    Ankeny, IA
    57
    Yes, I would have held out for the larger battery, did they tell you it was an exact replacement.... which it is not.
    Mar 2015
    Northville, MI
    496
    No, I knew it was not exact, a number of forum members have used the same size and many web sites give this size as the agm replacement formthe stock part. It is a 6AH battery, but it is also 130cca (there is a formula and they are different numbers) It turns the bike over great, the lights are noticeably brighter with no dimming at lower RPM (I am sure the old battery had been detriorating slowly over time). If you read through several of the batrery threads, it seems there is not an exact size replacement for the stock battery in AGM. If it works, I am happy to loose the weight too, it was probably 1.5 lbs. lighter than stock and up high on the bike.To each there own, I just wanted to report for those looking for alternatives.
    2002 TW200
    1998 DR350
    1996 KDX 200
    Nov 2016
    So. California
    164
    Be careful charging at more than an amp.
    Mar 2015
    Northville, MI
    496
    Stock TW can put out 2.5amps, so not to much different than in the bike@9k rpm. Charger is a semi auto and has agm setting (it auto adjusts voltage and charge rate), but it was pretty topped off anyway.
    2002 TW200
    1998 DR350
    1996 KDX 200
  1. New battery and tw will not maintain a charged battery
    By Mr.wiggle in forum Technical Help
    Last Post: 06-27-2016, 08:06 AM
  2. Battery Tender (battery) Headache
    By Dmd3058 in forum Technical Help
    Last Post: 04-03-2016, 04:10 PM
  3. Battery life sucks...what battery are you using?
    By rastaman in forum Technical Help
    Last Post: 11-02-2015, 01:14 PM
  4. Replies: 13
    Last Post: 03-15-2015, 09:04 PM
  5. Replies: 3
    Last Post: 02-05-2015, 11:55 PM
