Tw parts worth - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Like Tree61Likes
Thread: Tw parts worth
  1. #11
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    134
    Waymore what would be really cool is if you could buy that 89 TW200 in New York for $1200. Then take your time and have two of them little by little you could swap parts back and forth and find all the problems. Thats what I do, I have a 89 & 91. I hate to have to leave it with someone else for repairs.
    jtomelliott49 and Waymore like this.
  2. #12
    Member Waymore's Avatar
    Apr 2017
    Payson, Utah
    64
    I would love to do that i just think shipping it here would be a nightmare. But I'd love to have two bikes
    jtomelliott49 likes this.
    1992 TW200 6300 miles. Supposed engine rebuilt by previous owner
  3. #13
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    543
    What is the problem with the bike? Is it running rough or not running at all.Your problem could be really simple like bad fuel.
    Maybe it's the CDI.More info please.
  5. #14
    Sep 2014
    Mamaroneck, NY
    1,857
    Yep. If it is running that is half the battle. Running poorly could be a multitude of things.
    Sent from my SM-N920P using Tapatalk
    Waymore and jtomelliott49 like this.
  6. #15
    Apr 2017
    Payson, Utah
    64
    It sounds like there is something broken and bouncing around inside the engine, it won't idle anymore intact it barely wants to run at all with throttle and it gets so hot in a matter of 30 seconds you can't even sit on it or stand near it. It's not over revved or anything it just gets EXTREMELY hot real quick
  7. #16
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,120
    What does the spark plug look like? Sounds like a lean condition.
  8. #17
    Apr 2017
    Payson, Utah
    64
    Spark plug is dark brown but looks in good shape. It's only got about 150 miles on it at most
  9. #18
    Junior Member Pete H's Avatar
    Dec 2016
    Upstate NY
    6
    With only 6200 miles, I'd first clean it up to see what I've got. Any neglect will likely be due to weather and/or lack of maintenance. You've got to be either extremely cruel or stupid to hurt one of these. Air cooled, simple carb. CDI?, they either work or don't. So if it's gone this far, it will keep going. Might have some wiring connector issues if it's been left in weather.
    Carb rebuild kit, probably a petcock and fuel lines. Clean the tank and replace the air filter, and for god sakes change the oil and filter.
  10. #19
    Apr 2017
    Payson, Utah
    64
    Rebuilt the carb already changed the oil and filter twice. Have a Clarke tank on the way with a petcock. Went through almost all the connections and repaired broken connectors, changed the air filter, adjusted the valves and timing chain, replaced both sprockets and chain
  11. #20
    Senior Member DrTerrible's Avatar
    Jun 2016
    Sherwood Park, AB
    234
    I got extremely lucky. I posted on Facebook that I was looking for someone to rebuild my motor. You wouldn't believe all the backyard mechanics that are willing to help for a fraction of the price. Just ask loads of questions and use your best judgement. Plus, they will do the work at their place!
    Waymore, Tweaker and jtomelliott49 like this.
  1. What do you think my TW is worth?
    By Stoeger1201 in forum General Discussion
    Last Post: 09-09-2015, 11:05 AM
  2. Worth a look
    By naluboy in forum Off-Topic
    Last Post: 04-08-2014, 09:29 PM
  3. How much do you think it's worth?!
    By TwDuke in forum General Discussion
    Last Post: 09-13-2013, 07:19 AM
  4. How much is my TW worth?
    By decade03 in forum General Discussion
    Last Post: 05-10-2013, 11:21 PM
  5. Worth It?
    By Rawclam in forum General Discussion
    Last Post: 04-01-2011, 09:18 AM
