Getting ready! - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Like Tree75Likes
Thread: Getting ready!
  1. #11
    Member Fast Eddie B's Avatar
    May 2017
    Mineral Bluff, GA
    45
    I think my plan is to change my oil first at 150 miles, then again at 300.
    I have a gallon of 10w40 Yamalube arriving today, and I'll use that for these first couple of oil changes. Maybe switch to synthetic at 600 miles.
    jtomelliott49 likes this.
  2. #12
    Junior Member Cubby's Avatar
    Apr 2017
    Montana
    14
    I see a lot of people are not switching to synthetic oil till later on, why is that. Should a person break the motor in on dyno oil first? Thanks for all the advise guys, this forum is a great help.
    Ken and jtomelliott49 like this.
    2016 TW200
    2016 Skidoo T3 154"
    2015 Polaris XP1000 Sportsman
    2013 Polaris XP850 sportsman
    2016 Polaris RZR 170
  3. #13
    May 2017
    Mineral Bluff, GA
    45
    Traditionally, engines need to be "broken in". Rings have to wear to mate properly with cylinders, etc. Aircraft engines, also air cooled for the most part, use mineral oil for this phase - up to around 25 hours or until oil consumption stabilizes.
    Too light a load or too effective lubrication can delay this process or prevent it from ever happening.
    That said, modern water-cooled engines are engineered to such tight tolerances they ship with synthetic oil and can recommend first oil changes at 10,000 miles or so. As primitive as the TW200 motor is, I plan on dino for the first little bit - I think 600 miles should do it.
    But that's hardly the only way to do it, and I'm sure alternative methods complete with anecdotes abound!
    Ken, jtomelliott49 and Tweaker like this.
  5. #14
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    6,127
    I am a firm believer in full synthetic but only because that is what works for me. Purely a personal choice and I also believe all this hype about break in is just that-Hype.
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
  6. #15
    May 2017
    Mineral Bluff, GA
    45
    We can debate whether it applies to the TW200 motor or not, but its hardly just hype.
    From one manufacturer's "Tips On Engine Care":
    Tweaker and jtomelliott49 like this.
  7. #16
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    636
    I have used dino oil in mine and upon occasion I have used synthetic. I have used oils others say are taboo and have had very little engine wear. I have always broke mine in by manufacturers process. I really think the manufacturer suggests break in for less failure and warranty claims. Slow easy break in will probably catch and flush possible debris left in by manufacturing. I was reading about a v10 dodge viper brought to a track brand new and blew the engine. Professional race track mechanics found debris in the cam channel. Manufactures did not honor the warranty.
  8. #17
    Hailey, ID
    2,485
    Quote Originally Posted by Fast Eddie B View Post
    I'm in the "not hype" camp, too. I went to 1500 miles on Yamalube 10w40 dino before switching to Mobil 1 4T 10w40 full synthetic. At 15,000 miles my bike uses about 1/4 qt between 1500 mile oil changes. The BMW, on the other hand, had full synthetic from day one. Two completely different engine technologies; the TW is much closer to aircraft engine technology which is essentially 1930's.
    Rocky
    2010 TW200
    2014 BMW R1200GS LC
  9. #18
    Dec 2015
    San Diego
    1,049
    Yes, it certainly does...use this format instead: site:http://tw200forum.com/ fork tuning etc.
    Don't forget the space!
    And change your oil NOW and again in 200 miles!!! (at least!)
    Thanks for the correct format rocky.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
  10. #19
    Jun 2013
    Forestburgh, NY
    6,127
    These manuals make me laugh. I have 2 right in front of me, TW200 B & BC and the TW200 W & WC. Both show the capacity with filter change as 1.2 US Quarts. Both also show the Total oil capacity as 1.4 US Quarts which probably reflects the fact we can't get all the original oil out unless we split the engine cases. Both only give an oil spec as Yamalube type 4 SE but these are manuals from a 1989 and 1991 TW. The engines to the best of my knowledge are all the exact same right from 1987 up to 2017 with only some minor differences such as the Stator/charging/electrical systems and a different carb starting in 2001
    jtomelliott49 and Dryden-Tdub like this.
    2006 TW200
    2006 XT225
    1989 Lowe Lunker
  11. #20
    12,596
    And as one can see for most climates this time of year there is significant overlap of both 10w30 and 20w40 motor oils. That said I shall change over to 200w40 before Summer gets serious here. I usually try to avoid +90 degree riding.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  1. just about ready to buy
    By allen in utah in forum General Discussion
    Last Post: 01-31-2016, 11:37 AM
  2. Getting Ready for Moab
    By Hoot Gibson in forum Off-Topic
    Last Post: 05-20-2015, 10:31 PM
  3. Ready for winter?
    By Borneo in forum Off-Topic
    Last Post: 11-04-2014, 02:05 PM
  4. Getting ready for the new bike
    By joshisrael1 in forum General Discussion
    Last Post: 10-27-2014, 07:29 AM
  5. I am ready!
    By ZDR1 in forum Off-Topic
    Last Post: 07-02-2014, 05:34 PM
