Getting ready!
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree77Likes
Thread: Getting ready!
    Junior Member Cubby's Avatar
    Apr 2017
    Montana
    15
    Getting ready!
    Ok before anyone jumps on me about searching for things before I ask a question, the search feature on this site sucks and I really would just rather ask the question and get a good clean answer rather then sift through 3 dozen threads to find my answer. So anyways if you don't have something nice to add please just hold your comments.
    I'm coming up on 200 miles on my 16 tw200 and am looking in to doing my first service. That being said I already know how to change the oil and clean the filter but my question is how much oil does it take to fill, and if I want to just use standard oil instead of synthetic what weight do you guys use. I have seen some say 10w40 and some say 20w50. Just wondering if you have to use oil that is made for motorcycles with wet bath clutches or if any brand should work. I'm just going to stick to cleaning the factory screen filter for some time before I replace it with a paper filter. Any help is appreciated.
    Ken, admiral and jtomelliott49 like this.
    2016 TW200
    2016 Skidoo T3 154"
    2015 Polaris XP1000 Sportsman
    2013 Polaris XP850 sportsman
    2016 Polaris RZR 170
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    162
    Quote Originally Posted by Cubby View Post
    First off, welcome to the forum!
    it takes about 1.2 quarts to fill up with oil. Most are using 10/40 weight oil as I do. I stayed with regular dino (Valoline) oil till 1800 miles before switching to synthetic (Mobil 4T 10/40 racing). Others have switched earlier w/o any reported problems. YES use ONLY oil that is good for wet clutch or you will have clutch slippage.
    Fred, Ken and jtomelliott49 like this.
    Member Eric's Avatar
    Jun 2014
    Helena, MT
    64
    Hi Cubby, I am over in Helena and I have used Valvoline 10W-40 for Motorcycles. Not many choices over here, but Walmart always has this and it's a decent price. I don't ride much below 30 degrees or so, other than shorter trips. Usually too much snow on the trails if it is less than freezing. I've did a climb from 4000 to 8000 feet in about 45 minutes in the dead of summer and have not had any problem with 10W-40. 320 pounds between me and the gear and it climbed right up and acted just fine. Have ridden 90 miles in 80 degrees or so and not issue either. As others said, really watch for the motorcycle/wet clutch versions. No clutch issues with the one I use. The Yamaha manuals mostly show 10W-30 or 20W-40. Mine is a 2013 and I have done 4 oil changes, always with Valvoline 10W-40 and I always just clean and re-use that metal screen filter rather than switching. Holding up great. Good luck. Maybe you have more oil options over there. Good luck.
    littletommy, Tweaker, Ken and 2 others like this.
    2013 (old stock bought new by me in 2015), 700 miles as of May 2016, 14/55 with DID o-ring at 50 miles, Cyclops 3800 LED, superbright.com tail/brake LED (1157-R45-T: 1157 Red), superbright.com turn signal indicator (BA9S-G4-32-12VAC: Green 32 Degree 12V), ebay bark busters, ebay wide footpegs, manracks with rotopax, 1 gal rotopax, plasti-dip on all plastics Oct 2015, ebay mirror extenders, 80% trail/20% road, ALL maintenance per manual, BY ME ONLY (more freq. oil changes, reusing orig. filter)
    Dec 2015
    San Diego
    1,064
    Welcome. 4T Motorcycle oil of your choice. 10-40 for colder and 20-50 for hot.
    You are corrrect the search is bad so use google TW200forum then what ever you are looking for ; Best oil, best front tire, best handguards, etc.
    littletommy, Rockit, Ken and 5 others like this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, modified Krator foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
    Senior Member AGman's Avatar
    Nov 2013
    Melbourne, Australia
    656
    Not too sure about the paper filter in these engines. They run a low pressure oil pump, I'd be staying with the factory filter. These engines tell you when the oil is crap or inappropriate specs, when they get hot the gearbox gets notchy and hard to change. A better oil or spec will hang on as it gets hotter.
    Ken, Cubby, jtomelliott49 and 1 others like this.
    Resident Hidden Content specialist. Hidden Content
    Member chuckgarrett's Avatar
    Mar 2017
    Meridian, CA
    56
    Getting ready!
    Definitely do not use standard oil, not that I have, it will make the clutches act up, not that I have. Standard oil is a no no, not that I have.
    I found Valvoline motorcycle oil at WallyWorld. It works a lot better. 10-40w. I read in the manual it calls for "JASO MA" spec oil.
    Ken, Tweaker and jtomelliott49 like this.
    6,011
    One liter of oil -- or one quart plus 54 ml or 54 cm^3.
    Hailey, ID
    2,509
    .... the search feature on this site sucks .....
    Yes, it certainly does...use this format instead: site:http://tw200forum.com/ fork tuning etc.
    Don't forget the space!
    And change your oil NOW and again in 200 miles!!! (at least!)
    Ken, Cubby, Tweaker and 1 others like this.
    Rocky
    2010 TW200
    2014 BMW R1200GS LC
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    6,216
    My owners manual says 1.4 US quarts with the filter change. I use kerosene to clean the stock filter and I always switch to full synthetic because it shifts smoother and the engine runs cooler.
    lugnut, Cubby and jtomelliott49 like this.
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
    Senior Member lugnut's Avatar
    Apr 2017
    alliance ohio
    118
    I did my first oil change at 78 miles. I switched to Mobil 4tr 10w-40 and have no clutch issues and it shifts better. My bike takes 1 quart to fill.
    cycle rack, front rack, oil cooler, richocet skid plate, shinko 241, x-ring chain, jimbo shield, led lighting and boxes added to rack for storage and seat concepts comfort along with double take mirrors.
  1. just about ready to buy
    By allen in utah in forum General Discussion
    Last Post: 01-31-2016, 11:37 AM
  2. Getting Ready for Moab
    By Hoot Gibson in forum Off-Topic
    Last Post: 05-20-2015, 10:31 PM
  3. Ready for winter?
    By Borneo in forum Off-Topic
    Last Post: 11-04-2014, 02:05 PM
  4. Getting ready for the new bike
    By joshisrael1 in forum General Discussion
    Last Post: 10-27-2014, 07:29 AM
  5. I am ready!
    By ZDR1 in forum Off-Topic
    Last Post: 07-02-2014, 05:34 PM
