BW200N 1985 - Rattling Noise from Engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree4Likes
Thread: BW200N 1985 - Rattling Noise from Engine
    Junior Member supertarmac's Avatar
    Dec 2013
    13
    Hey guys,
    This is my first post, but I've been reading up on this forum for some months already.
    I wonder if you guys can help me out with some advice for my 1985 BW200N. Maybe someone has had a similar experience with his/ her TW.
    I got the bike around two months ago, but it did not have an air filter. So I rode it a bit just to test it and it ran LEAN. It would backfire, hesitate when opening the throttle past half way and the spark plug would come out white. It made a rattling sound which I assume was pre-ignition (pinging) and when idling when warmed up it would die. Also when having the throttle slightly opened (like 1/8) the rpms would go up and down, without changing the throttle position. I attributed all of this to the lack of air flow restriction because of not having an air filter.
    So the filter finally arrived. I installed it but nothing changed :huh. It still lacked a lot of power.
    So yesterday, I changed the needle setting to the first slot (richest), and the bike runs pretty good, but still has the rattling sound coming from the engine. Here is a video so you can hear it:
    <iframe width="560" height="315" src="//www.youtube.com/embed/HYE2A5LpNss" frameborder="0" allowfullscreen></iframe>
    It still dies while idling when it is warmed up (I have adjusted the rpm screw but it still dies) and when having the throttle at 1/8 it still goes up and down on rpm's without changing the throttle position.
    I have:
    Checked the gas cap for flow - OK
    Checked the fuel filter for obstruction - OK
    Cleaned the Carburetor throughly twice
    Checked Airbox and Carburator Rubber Connection for Leaks - OK
    Checked Spark Plug Gap and used a couple of new ones for reading
    I am using Premium Fuel
    Oil Filter is clean / Air Filter is new
    I am using Yamalube 10W-40 Mineral Oil
    The original owner almost did not use it. It has very low hours. The main jet is stock (#108) and I have the pilot crew at 1.5 turns from the closed position.
    I closed the pilot screw almost completely to make it run rich. It felt like it was running on choke, but it STILL had the rattling sound from the engine. So I don't know if the pinging sound is actually because of running lean? Or could the timing be off? Could it be the valves? Even if the bike has been used very very little.
    Here is how the spark plugs look right now. They have a white tip, but tan color on the lower part. Does it look like it is still running lean?
    Any advice will be greatly appreciated.
    Many many thanks.
    Spokane, Washington
    14,211
    Go the other way with the air/fuel screw to richen it. Try 2 1/2 turns out and go from there. Did you oil the air filter? Also, use regular not premium gas in it.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,097
    If your carb is the same as the TW you need to open the pilot screw around 2 1/2 turns out to start. You have a lean condition now, check for air leaks at the carb intake by spraying WD40 or starting fluid onto the boot.
    tripleted likes this.
    Dec 2013
    13
    Hi littletommy thanks. I almost closed it completely to richen it the most I could. It felt like it was running with the choke on and you could smell it running rich. It still had the rattling / pinging noise. I tried different positions with the pilot screw, and it runs best at 1 1/2 turns out (which is also what the manual states). Any other suggestions?
    Dec 2013
    13
    Thanks RBM.
    I did check for air leaks with WD40 on the boot and carb intake. The bike did not go up on rpm's when I sprayed it.
    I tried different positions with the pilot screw, and it runs best at 1 1/2 turns out (which is also what the service manual states). If I went out further, or went less it runs very poorly.
    Spokane, Washington
    14,211
    I would try going out another turn for a total of 2 1/2 out from bottoming out, then if nessesary adjust the idle screw so it is within specs. Did you oil the new air filter? Do these things first, then if it is still rattling and making noise, it could be the chain tentioner or valve adjustment, but I am assuming that those are ok, since it has low miles. Never hurts to check them though so you have the peace of mind that they are right.
    I am assuming that it is the same engine as the TW. Perhaps do as they say with the 1 1/2 turns and adjusting the idle, oil the filter, etc, first. Then try the 2 1/2 turns out..
    Dec 2013
    13
    OK littletommy will do. Just to make sure, I close it completely (clockwise), then open it 2 1/2 turns (counterclockwise)?
    Yes I oiled the filter and yes it is basically the same engine.
    Question: If the chain tensioner is out of adjustment, would it advance or delay the timing? Or what effect would it have?
    Many thanks again for the pointers!
    Spokane, Washington
    14,211
    Quote Originally Posted by supertarmac View Post
    OK littletommy will do. Just to make sure, I close it completely (clockwise), then open it 2 1/2 turns (counterclockwise)? correct. lightly seat it, then 2 1/2 out. Did you try it as the manuel says? 1 1/2?
    Yes I oiled the filter and yes it is basically the same engine. OK>
    Question: If the chain tensioner is out of adjustment, would it advance or delay the timing? Or what effect would it have? Noisy rattling.
    Glad to be of help.
    Spokane, Washington
    14,211
    Try some Lucus Deep Fuel Cleaner or Seafoam in it too. It would be better if you had regular gas in it too. Was the gas fresh that you have in it at least? Just for peace of mind, I would go ahead and check the valves and chain tensioner, then you know it's not them.
    *they are kinda rattling little engines anyway..so take that into consideration.
    Dec 2013
    13
    Yes it is now set on what the manual said 1 1/2 turns, but I will give it a try with the 2 1/2 turns.
    Yeap the gas is fresh. I emptied the old gas when I got it.
    OK I will check the chain tensioner and the valves. Thanks again for the pointers littletommy!
    I will keep you guys posted.
  1. odd rattling sound now oil leaking from cylinder head?
    By Braden in forum Technical Help
    Last Post: 10-05-2013, 04:28 PM
  2. Will 1985 xt600 fuel tank fit my 1996 TW200?
    By BikeNerd21 in forum Technical Help
    Last Post: 06-17-2013, 02:51 PM
  3. Light "rattling" sound when warm
    By jontow in forum Technical Help
    Last Post: 05-13-2013, 08:36 PM
  4. engine, tranny, or chain noise
    By gussy78 in forum Technical Help
    Last Post: 04-29-2013, 11:48 PM
  5. Parting out an 1985 Honda Fortrax 250
    By n2o2diver in forum Off-Topic
    Last Post: 02-16-2012, 07:48 PM
tw200 gear rattles
