Trail Tech Endurance II Install
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By randucci
Thread: Trail Tech Endurance II Install
    Junior Member UUes's Avatar
    Jul 2014
    Colorado
    1
    So I just finished installing my new Trail Tech Endurance II on my bike. I was hoping for more posts of others doing the same to gain a little guidance.
    So I improvised, and "Jerry Rigged" a bit to make it work.
    I use a mount that I had from an old mountain bike, 'Cateye', to position the sensor close enough to the magnet that I mounted on the front wheel with JB Weld. (See Pictures)
    The only think left to do is connect the power to the battery. (It will run on battery, so I'm not sure why it needs to connect to the battery) Not sure how to do this part yet. If anyone has any suggestions, that would most helpful!
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,396
    Checking the Trail Tech website, I see no reason that you 'need' to connect to the bikes battery. Currently I am running my Vector using only the button cell. Not sure how much night riding you do but this is likely the best reason to consider connecting to the bikes electrical system. The connection I used on my previous Trail-Tech units was a simple, wires direct to battery. Gerry
    Take care my Friend.........
    Senior Member randucci's Avatar
    Mar 2012
    Seattle, Wa.
    125
    I installed a Trail Tech Vapor on my bike and really like all the extra features. I didn't like how they wanted you to jury rig the speed pickup to the old spedo cable (especially since I wanted to remove it as I wasn't using it any longer). So I made a pickup adapter that used the old spedo cable mount on the hub.
    Ice_Man likes this.
  1. Trail Tech Voyager GPS Computer
    By Mystic Explorer in forum Performance and Customization
    Last Post: 04-15-2014, 08:02 PM
  2. Trail Tech TTO temp gauge?
    By DonBenito in forum Performance and Customization
    Last Post: 05-16-2013, 09:16 PM
  3. Trail Tech Voyager GPS review?
    By NiceAndSlow in forum Performance and Customization
    Last Post: 03-23-2013, 11:23 AM
  4. Vapor Trail Tech
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-21-2012, 01:33 PM
  5. New Trail Tech Vapor install for Muley
    By JS5owner in forum Performance and Customization
    Last Post: 01-01-2012, 08:01 AM
connecting trailtech endurance ii directly to battery
how to install the endurance trail tech 11
how wire my endurance ii to my battery
startup issues
trail tech endurance 2 on tw200
trail tech endurance ii photo
trail tech for 2014 tw200
trail tech speedo install
trailtech endurance tw200 install
tw200 trail tech install
Tags for this Thread
