HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD) - Page 12
Page 12 of 12 FirstFirst ... 2101112
Results 111 to 118 of 118
Like Tree53Likes
Thread: HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD)
  1. #111
    Junior Member Tceparker's Avatar
    Nov 2016
    10
    I'm not sure how to upload pics from my phone,...
    The bike is pictured in classified I bought it from 300stw.
    I'll try and figure out the pics thing..
    littletommy likes this.
  2. #112
    Nov 2016
    10
  3. #113
    Nov 2016
    10
  5. #114
    Junior Member mikejana's Avatar
    Mar 2016
    12
    Easy to bolt the whole front end from a BW on the TW. I've even got a TW headlight assembly on my BW200.
    Morning the instruments is easy, here is my solution on my TWW 200:
    Headlight and brackets from eBay:
    Sent from my iPhone using Tapatalk Pro
  6. #115
    Nov 2016
    10
    Very nice! Disc brake....please explain.. Did you have a disc front Tw? Then is that a tw rear wheel? Did you have to build it with the original front hub?
    Very nice bike!
  7. #116
    Senior Member ChopperCharles's Avatar
    113
    I have some thoughts and questions:
    1. Is it possible to simply lace a rear rim to a front hub? Make a spacer for the brake disc to move it to the side for clearance, and then you've got basically an OEM setup for the front brake and speedometer drive. (so long as you use TW200 forks). Will have to have an axle machined too, come to think of it.
    2. Is it possible to machine an adapter to mount the OEM disc brake to the sprocket flange? That might make things a lot easier. Again, using TW200 forks.
    3. I'm thinking with that front end the way it is, a fork brace looks like a really good idea. The TW200 has a metal piece under the fender that acts as a brace, and you're removing that to go with BW200 forks.
    4. Your steering is slower for two reasons - the fatter front tire, and the increased trail due to the longer BW200 forks. Using TW200 forks will alleviate part of the issue. A longer rear shock will help reduce trail further, and quicken your steering up. You'll never get back to OEM handling, but you can probably make it a lot better. Wide handlebars will help too.
    Charles.
    Purple and centralwarider like this.
  8. #117
    Pleasanton, CA
    4,366
    Hi Charles, here are some answers and comments to your questions:
    1. Is it possible to simply lace a rear rim to a front hub? Unfortunately, the stock TW front and rear wheels have different spoke counts. I believe that the front has 36 spokes and the rear has 32 spokes, so you would either need a custom rim or a custom hub. Below is a picture of a TW rear rim that I had mounted to a billet Honda CRF150 hub that I had intended to use for my second generation TWW project that I have since abandoned. Make a spacer for the brake disc to move it to the side for clearance, and then you've got basically an OEM setup for the front brake and speedometer drive. (so long as you use TW200 forks). This could be done, but in order to use a stock TW front hub you would need to have a custom rim made with the higher spoke count. Will have to have an axle machined too, come to think of it. Not if you used the stock TW front hub.
    2. Is it possible to machine an adapter to mount the OEM disc brake to the sprocket flange? This might work. That might make things a lot easier. Again, using TW200 forks.
    3. I'm thinking with that front end the way it is, a fork brace looks like a really good idea. The TW200 has a metal piece under the fender that acts as a brace, and you're removing that to go with BW200 forks. I agree.
    4. Your steering is slower for two reasons - the fatter front tire, and the increased trail due to the longer BW200 forks. Using TW200 forks will alleviate part of the issue. A longer rear shock will help reduce trail further, and quicken your steering up. You'll never get back to OEM handling, but you can probably make it a lot better. Wide handlebars will help too. I agree.
    Charles.
    site:tw200forum.com
  9. #118
    Nov 2011
    norcal nutjob
    2,845
    Chopper Charles! wow a sighting, hope all is well with you!
  1. BW triple trees for wide front wheel mod?
    By TeeDub in forum Performance and Customization
    Last Post: 05-26-2017, 12:08 PM
  2. PICTURES OF TWW MOD (TWO WIDE WHEELS)
    By mmannddalla in forum Performance and Customization
    Last Post: 05-26-2015, 02:55 AM
  3. Replies: 1
    Last Post: 09-20-2011, 07:06 PM
  4. Wanted TW200 with wide front conversion ,racks, etc
    By emilliano in forum TW200 Classifieds
    Last Post: 03-13-2011, 09:16 AM
  5. 87-00 Front Forks/Triple Trees/Front Wheel/Swingarm
    By TWmonster in forum TW200 Classifieds
    Last Post: 09-26-2010, 09:11 AM
3 inch fat front end for yamaha
bw200 forks on tw200
bw200 mods
custom fork brackets for wide front tires for xt 250
custom mods for bikes putting fat tyre rims on my xt 250
fat tires on a klr 650
klr650 fat tire
tw200 fat front tore
tw200 tww
yamaha tw 400
yamaha tw200 tire conversion
yamaha xt250 customized with fat tires
