HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD) - Page 2
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 118
Like Tree53Likes
Thread: HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD)
  1. #11
    Member mmannddalla's Avatar
    Nov 2010
    62
    FINAL PRODUCT
    PlacerLode and overheat like this.
  2. #12
    Ephrata, WA
    1,125
    What an awesome write up and pictures to go with it, you did an excellent job. You have yourself a sweet looking machine. Thank you.
    1990 TW200
  3. #13
    Senior Member dhoenisch's Avatar
    Chicagoland, IL
    512
    Can I assume you converted those two fuel cans as panniers? Pretty neat and inexpensive idea.
    Dan
    2009 Yamaha TW200
    1996 Yamaha Virago 1100
  5. #14
    Nov 2010
    62
    Quote Originally Posted by dhoenisch View Post
    Dan
    YES, THEY ARE PLASTIC JERRY CANS,YOU CAN CHECK THEM IN THE TOPIC
    PVC RACK AND PLASTIC GAS CONTAINERS AS PANNIERS
    I USE THE PVC RACK DAILY FOR 4 MONTHS WITH ZERO PROBLEMS.
    NOW I SAVED SOME $ AND PUT HAPPY TRAILS FRONT & SIDE RACKS.
    I KEEP USING THE PANNIERS. I WILL INSTALL THE PVC RACK ON THE FAT CAT.
  6. #15
    10,665
    AWESOME!!!!
    Okay, I now have a really bad headache from reading your CAPSLOCK writeup. Worth every throb.
    Question: You mentioned the BW forks being "lower" than the TW forks, but your bike does not appear to be sitting low in the front in the pictures. Do you mean the axle is lower in relation to the triple tree?
    Might I suggest the TW32 tread pattern would likely work better on the rear wheel and the TW34 would likely work better on the front. Function aside, those TW32s are old, and old tires often fail in spectacular fashion. A blowout on a front tire is much more dangerous than a blowout on a rear tire. Just for safety's sake, mount a new TW34 on the front and save the TW32 for the back. Genius like yours would surely be missed.
  7. #16
    Nov 2010
    62
    AWESOME!!!!
    THANKS.
    THE BW200 FORKS ARE LONGER BY 2 ", NO LOWER.
    I WILL USE TW32 REAR AND TW34 FRONT AS YOU SUGGEST. THANKS
  8. #17
    10,665
    Quote Originally Posted by mmannddalla View Post
    THANKS.
    I went back and reread your part about the forks. Darn dyslexia makes it very hard for me to read ALL CAPS.
    I'm planning dual stock front disc and calipers on custom spacer/adapters and a TW34 tire, a slightly extended swingarm, and an ATV rear tire on a 12-inch aluminum trailer wheel with the stock front disc and caliper for a brake. All it takes is money, and all mine is going to pay off medical bills right now.
  9. #18
    Senior Member shocker's Avatar
    Orange Park, Florida
    164
    This looks great. I am on my second TW and always liked the fat tire on the front idea. Starting looking into more seriuos as of late and I used some info from this post to undertake the project. I am going in a little different area with the brake, as I did'nt want the rear brake(smaller)on the front. So if you look at the drum brake model tw's the brake drum is bolted to the hub with a 3 bolt ring. This is the same on front and rear. I purchased an extra set of rims(front and rear) and removed the front brake hub from the wheel hub(spoke holes are evident)and bolted it on the rear rim. The rear hub sprocket flange has to be removed(alot of cutting and grinding) and hub trimmed with one bearing removed just like mmannddalla did. Also, I'm using the stock tw forks in the BW 200 triple tree so I drilled out the forks axle holes and front wheel brake hub hole to use the larger rear axle. The front axle is 15mm diameter while rear is 17mm. So not much material is removed for that, and then the front brake hub slips into front fork leg retainer without modification there. Also had to cut rear axle spacers to get wheel centered in forks(have to use rear stuff to fit axle). I'm still in work as I have to mount my Shinko tires front and back. I also am going to paint both rims black.
  10. #19
    164
    Forgot to mention that the bw 200 triple tree and bearings are a bolt in but the one I have needs a mod on the steering stop to keep the fork leg from hitting the tank on one side.
  11. #20
    Member Hendragster's Avatar
    Aug 2010
    Largo, FL
    68
    this beast looks sweet...! thx for sharing
    - RIDE -
  1. PICTURES OF TWW MOD (TWO WIDE WHEELS)
    By mmannddalla in forum Performance and Customization
    Last Post: 05-26-2015, 02:55 AM
  2. BW triple trees for wide front wheel mod?
    By TeeDub in forum Performance and Customization
    Last Post: 11-08-2014, 07:57 PM
  3. Replies: 1
    Last Post: 09-20-2011, 07:06 PM
  4. Wanted TW200 with wide front conversion ,racks, etc
    By emilliano in forum TW200 Classifieds
    Last Post: 03-13-2011, 09:16 AM
  5. 87-00 Front Forks/Triple Trees/Front Wheel/Swingarm
    By TWmonster in forum TW200 Classifieds
    Last Post: 09-26-2010, 09:11 AM
3 inch fat front end for yamaha
bw200 forks on tw200
bw200 mods
custom fork brackets for wide front tires for xt 250
custom mods for bikes putting fat tyre rims on my xt 250
fat tires on a klr 650
klr650 fat tire
tw200 fat front tore
tw200 tww
yamaha tw 400
yamaha tw200 tire conversion
yamaha xt250 customized with fat tires
