HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD) - Page 3
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 118
Like Tree53Likes
Thread: HOW TO MAKE A TWW MOD ( TWO WIDE WHEELS ) (FAT FRONT WHEEL MOD)
  1. #21
    Senior Member shocker's Avatar
    Orange Park, Florida
    164
    Got my TW FAT front tire conversion ready for test ride this past weekend. I like it so far. Would load a photo but like others not getting desired results putting them on this forum. The insert image icon is ineffective.
  2. #22
    Member mmannddalla's Avatar
    Nov 2010
    62
    Quote Originally Posted by poolsgold View Post
    Hey, nice to know that somebody else has done the TWW mod.
    I would like to see your pics and the mod for the front brake, I think is a very good idea.
    (Had you been trying to upload your pics first in photobucket, and then get the url to paste here?)
    Cheers
  3. #23
    164
    post of in work photo.Picture shows the original front brake hub removed from 18" wheel and bolted to rear wheel hub with axle hole drilled to fit rear larger axle. Spoke holes in front brake hub are open as this was unlaced from original front wheel. Test fit mount before Shinko 428 tire installed.
    PlacerLode and grewen like this.
  5. #24
    164
    this side has the sprocket flange removed and wheel hub cut to 3" and 1 wheel bearing removed. Rear wheel axle spacers were cut to give proper center of wheel in front forks.
    PlacerLode likes this.
  6. #25
    164
    Here is the BW 200 triple tree mounted using TW stem bearings. Fork legs axle holes are drilled out to use 17mm rear axle(front axle is 15mm)
  7. #26
    164
    Ready for a test ride with Shinko 428 tire mounted. Still working the headlight mod and turn signals. FATTY!
    PlacerLode and lated like this.
  8. #27
    164
    I also cut 6 inches off the front of the seat pan and removed some seat foam then recovered the seat with new upholstery. Purchased a 45 tooth rear sprocket and installed along with o-ring chain. This vintage 1987 TW 200 is looking pretty fresh and runs excellent. I did this change to my first TW and liked the 45 tooth rear over the 50 and 47. So this being my second TW I went for the 45 right away.
  9. #28
    164
    I test rode about 15 miles so far and the steering is a bit different with the Fat front tire but not bad. You can feel the gyro effect of the spinning heavier tire/wheel assembly more. It is totally useable and the stock front brake feels as good as with the 18" front wheel. I had the TW up to 45 mph actual but the speedo is off because of the smaller overall size of the FAT front tire so indicator reads 52 @ 45. And I love how it looks!
  10. #29
    Pleasanton, CA
    4,280
    Very cool! Nice job. I really like your idea of adapting the front brake hub to the rear wheel that is used up front. Looks much cleaner, requires fewer modifications and provides better braking. As soon as I collect a few more parts I will be starting my fat front wheel mod using your approach. Thanks!
    Brian
    site:tw200forum.com
  11. #30
    164
    Gotta give mmanddalla the most credit as his pictures put me over the edge for getting it going. If you have the front disc brake model TW you will have to post how you convert it to fit the fatty and keep the disc.
  1. PICTURES OF TWW MOD (TWO WIDE WHEELS)
    By mmannddalla in forum Performance and Customization
    Last Post: 05-26-2015, 02:55 AM
  2. BW triple trees for wide front wheel mod?
    By TeeDub in forum Performance and Customization
    Last Post: 11-08-2014, 07:57 PM
  3. Replies: 1
    Last Post: 09-20-2011, 07:06 PM
  4. Wanted TW200 with wide front conversion ,racks, etc
    By emilliano in forum TW200 Classifieds
    Last Post: 03-13-2011, 09:16 AM
  5. 87-00 Front Forks/Triple Trees/Front Wheel/Swingarm
    By TWmonster in forum TW200 Classifieds
    Last Post: 09-26-2010, 09:11 AM
3 inch fat front end for yamaha
bw200 forks on tw200
bw200 mods
custom fork brackets for wide front tires for xt 250
custom mods for bikes putting fat tyre rims on my xt 250
fat tires on a klr 650
klr650 fat tire
tw200 fat front tore
tw200 tww
yamaha tw 400
yamaha tw200 tire conversion
yamaha xt250 customized with fat tires
