Trailer Wheel (TW) Mod for the TW200 - Page 3
Page 3 of 30 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 295
Like Tree606Likes
Thread: Trailer Wheel (TW) Mod for the TW200
  1. #21
    Pleasanton, CA
    4,237
    Fred's comments are spot-on. I ran the same size Duro as Fred in the stock swingarm shown below for at least 2,000 miles without problems. As you can see, there is some evidence of paint damage on the right side which is where the pinch point occurs with ATV tires in the stock swingarm.
    The pictures below illustrate the clearance on either side of the stock swingarm. I found it necessary to remove the lower chain guard bracket when I mounted the Duro. Clearance will also depend on your chain and how far rearward it will allow your axle to slide in the frame slots.
    TWilight and jtomelliott49 like this.
    site:tw200forum.com
  2. #22
    12,286
    So Dan, as an Oregonian you must own a chainsaw. Perhaps you could avoid the extended swing arm with a little clever sidewall carving.
    jtomelliott49 likes this.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  3. #23
    Senior Member HKLBRY's Avatar
    Mar 2014
    Creswell, Oregon
    168
    Well, I have 8 chainsaws in the garage, so that could be done.
    When I was experimenting with my front tire this summer, I actually found the a good sharp carpenters chisel wil go through the tread like butter, so if I need to take a little corner off it won't be a problem. I just am not sure if I want the expense of lengthening the swing arm to do this mod. I have to watch the build budget and spread out these mods over time. So the 12" rim sounds like the route I will go, and may extend the swing arm later if I feel there is a need.
  5. #24
    12,286
    I was joking about the chain saw.
    On a serious note I really feel the the 12" trailer wheel conversion will permit choosing a tire that does not come dangerously close to the stock unmodified swing arm.
    For example here are a few 25x8x12 examples from Maxis and a Dirt Devil .41myzCpdnFL._SL500_AA500_.jpg
    The typically installed Duros or Bighorn IIs are a good inch or more taller, with squarish profiles and protruding side lugs. These are the features that bring those ATV tires into close proximity to the right side of the swing arm up where the swing arm gap starts to neck in.
    I showed the Maxis on top to show how rounded a profile is available in a smaller, lighter package. There are lots of options of varying aggressiveness.
    Active Thumpers:
    1981 KDX175 Enduro
    1982 YZ250G MX
  6. #25
    Pleasanton, CA
    4,237
    Here is the Maxxis Ceros, it comes in both 26x8x12 and 25x8x12. Not as square and blocky as the Duro
    Fred and plumbstraight like this.
    site:tw200forum.com
  7. #26
    Poway CA.
    1,929
    Bryan is there a aluminum rim option?
    ronnydog
  8. #27
    Pleasanton, CA
    4,237
    Quote Originally Posted by ronnydog View Post
    ronnydog
    I don't see any reason why an aluminum rim could not be made to work. My only concern would be since an aluminum rim would be thicker in the mounting area, this would require removing even more material to make the notches that allow the sprocket mounting hub to pass through the center of the rim. There is a limit as to how much material can be removed before compromising the integrity of the rim, but I do not know what that limit is.
    Unfortunately, the sites that I have looked at do not post the weights of their rims, so I do not know what the weight savings with an aluminum rim would be.
    site:tw200forum.com
  9. #28
    Senior Member Ricklesss's Avatar
    Feb 2015
    Dexter, OR
    155
    GREAT new posting of a great subject. I've been interested in this mod since the first time I ran across it here.
    It just makes so much sense.
    I especially like the idea of reduced swingarm intereference using the 12" wheel, especially for the Oregon mud we have.
    I can imagine there will be a run on used Tdubb wheels on ebay...
    (last one there is a square"!)
    Yup, I'm in...
    RicklesssS in Oregon
    * Hi Huckleberry!
  10. #29
    Sand Hollow, ID
    9,299
    Is Mike willing to share the measurements he welded the rim hub and brake hub in this photo? Particularly if I were to use the exact same rim.
    Also, can you share out you cut out the notches in the rim between the hub bolt holes?
    Of course, I ask these questions with the intentions of spending $175 and send it to Mike anyway! Asking just in case.
    Thanks
    Dryden-Tdub likes this.
  11. #30
    Pleasanton, CA
    4,237
    Admiral,
    I will try to get this information for you, but in the interim I will explain how these dimensions can be derived.
    -Brake mounting plate - After the outer spoke ring is removed from this plate, this plate is removed from the hub shaft in order to allow the removal the inner spoke ring. Therefore it is necessary to measure, or mark, the original position of the brake mounting plate so it can be returned to this original position.
    -Rim mounting plate - I provided Mike with a complete TW rear wheel so that he could determine where the centerline of the trailer wheel needed to be with respect to the axle hub. The trailer rim is centered (i.e. no offset) so the surface of new rim mounting plate with the lug bolt threads needs to correspond with where the centerline of the TW rim used to be.
    -There should be some slight allowances made to allow for the final truing of these two plates after welding.
    Let me know if this makes any sense to you.
    Brian
    PlacerLode and Fred like this.
    site:tw200forum.com
  1. 2 Wheel Tank Trailer
    By ronnydog in forum Performance and Customization
    Last Post: 10-04-2014, 11:12 PM
  2. Trailer Wheel Bearings
    By elime in forum General Discussion
    Last Post: 09-22-2014, 06:15 PM
  3. Custom Built Trailer Hitch Carrier for a TW200
    By Fursniper in forum General Discussion
    Last Post: 09-17-2014, 10:39 PM
  4. Oh my, a 3 wheel TW200
    By unclejemima in forum General Discussion
    Last Post: 07-21-2012, 02:18 PM
  5. trailer pulled by a TW200
    By RingSteel in forum General Discussion
    Last Post: 07-07-2012, 08:52 PM
bw350
rear hub
trailer wheel
tw200 sedona ripsaw
tw200 trailer rear wheel
tw200 trailer tire hub
tw200 trailer wheel
