TW Run Flat Rear Tires! - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Like Tree146Likes
Thread: TW Run Flat Rear Tires!
  1. #21
    Sand Hollow, ID
    9,515
    Quote Originally Posted by 1911garand View Post
    My quest for an "Air Optional" TW200 continues.
    I found a front tire that should be as close to run flat as one can get.
    The Kenda K270 in 4.50-18 is a 6ply (part number 042701858C0) with a load rating of 365lbs and max pressure of 40psi. That tire should have super stiff side walls.
    Kenda Tire | Powersports | K270 Dual Sport
    Anyone have experience with that one?
    Also, I now see they make a K787 EQUILIBRIUM DOT approved which is also 4.5-18 6ply, but more aggressive tread and twice the price as the K270.
    Kenda Tire | Powersports | Equilibrium
    Thanks!
    I used a 5.10x18 Shinko SR244, which is very similar to the Kenda 270. Not on purpose, but one time I guesstimated letting air out of my tire for off-road riding. I rode it that way quite a while before airing back up. Turned out I was running with 0 psi. I have heard of one other individual riding on either a K270 or SR244 with a flat it they were able to keep riding. So, these tires may have some "run flat" capability but you won't know unless you bought one to find out. I guess I could go test the theory on my wife's TW as it has a 4.60x18 SR244 on it. Maybe I'll try it tomorrow and let you know.
  2. #22
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    710
    I got Then Kenda K270 4.50-18 6ply today.
    Kenda has the specs wrong on the web site. The tire sidewall says 800 lbs max load at 40psi - great!
    The side wall is good and stiff. I'll fit it up this weekend and take 'er for a rip.
    Good luck
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  3. #23
    Nov 2015
    Great White North
    710
    What a nice day to test out the new Kenda K270 4.50-18 6ply. The K270 Looks and performs much better than OEM tire. Not sure if it will run without air, but it is way "heavier duty" that the stock tire.
    The previous owner had just installed a new Michelin heavy duty tube, so that was a nice surprise.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  5. #24
    Apr 2014
    Dryden NY
    5,543
    Could you feel the weight difference up front with that tire and tube vs. the stocker?
    Tom
    Never, in the history of mankind, have lives, less lived, been so well chronicled.
  6. #25
    Nov 2015
    Great White North
    710
    Quote Originally Posted by Dryden-Tdub View Post
    Tom
    No, I did not notice any changes due to weight. These bike are so slow the way it is...hard to tell any difference.
    I did notice a slower turning response on tar (going through round-a-bout), but really it wont effect normal off road driving.
    Biggest improvement - Mud and Loose dirt road driving. The stock tire would snake and wiggle in the loose stuff and not keep straight line. The K270 with the ATV tire in the back goes where I aim it.
    The K270 was well worth the $55.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  7. #26
    Apr 2014
    Dryden NY
    5,543
    I do appreciate the reply thank you. I have heard differing opinions on some of these tires but not the one you selected.
    Tom
    littletommy and 1911garand like this.
  8. #27
    Nov 2015
    Great White North
    710
    So far so good with the run flat rear and the K270 front. I have put approx 300 miles on so far with this combo.
    I hope to on put LOTS more off road miles on this summer and will report any issues.
    Thanks dudes!
    Ledmelon and akalogan like this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  9. #28
    Member Ledmelon's Avatar
    Mar 2016
    Va. USA
    91
    Your TDUB looks awesome!
    cowboyjeff likes this.
  10. #29
    Nov 2015
    Great White North
    710
    Quote Originally Posted by Ledmelon View Post
    Thanks - These little bikes are more fun and addicting than glossy magazines.
    littletommy and JerseyJeeper like this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  11. #30
    Nov 2015
    Great White North
    710
    So - With the big back tire installed, my gearing isnt the best for slow climbing, but great for cruising gravel roads and trails.
    The bike has new, stock gearing and new Oring chain. (14/50)
    My rear adjusters are on setting #4, lots of adjustment left.
    Thinking about going to a 55 tooth rear sprocket - will I need a longer chain or chain extension?
    Thanks!
    JerseyJeeper likes this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  1. If Rear tire is flat?
    By Phantom99 in forum General Discussion
    Last Post: 07-08-2015, 12:16 AM
  2. Anybody tried the Michelin T63 tires? Front and rear?
    By Flathats in forum Performance and Customization
    Last Post: 06-26-2015, 09:17 PM
  3. HoverBike - No More Flat Tires
    By Fred in forum Off-Topic
    Last Post: 06-18-2015, 06:56 PM
  4. New member: Help witih rear tire flat please
    By Zachary in forum Technical Help
    Last Post: 07-17-2014, 09:32 PM
  5. flat tires on the trail
    By norcaloz in forum General Discussion
    Last Post: 06-29-2014, 01:18 AM
battery
carlisle trail pro
