TW Run Flat Rear Tires! - Page 4
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Like Tree146Likes
Thread: TW Run Flat Rear Tires!
  1. #31
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,247
    Quote Originally Posted by 1911garand View Post
    So - With the big back tire installed, my gearing isnt the best for slow climbing, but great for cruising gravel roads and trails.
    The bike has new, stock gearing and new Oring chain. (14/50)
    My rear adjusters are on setting #4, lots of adjustment left.
    Thinking about going to a 55 tooth rear sprocket - will I need a longer chain or chain extension?
    Thanks!
    Does this help? Does someone else have a calculator to confirm this one is CORRECT? (EDIT 6-8-18 LINK Calc is incorrect) Buy a bigger one anyway, press off the links you do not need and keep them as spare. X- Ring chain is your best bet.
    1911garand likes this.
  2. #32
    Mar 2011
    2,247
    Any updates on the rear tire?
    littletommy likes this.
  3. #33
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    680
    No updates.
    The Kenda K270 front (4.50-18) and Run Flat rear (Carlisle Terrathon ERT 26x8-14) are working great.
    I am running the front a 15psi and the rear at 8 psi. I had them at 30psi and 15 psi earlier and that was too much, didn't feel right.
    I have not played with the gearing yet, it is factory gearing and I can "easily" hit 60 mph.
    Most of my riding is trail / gravel road, so the factory gearing (for now) is perfect for the flat lands of MN.
    What other update were you looking for?
    Thanks!
    littletommy and admiral like this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  5. #34
    Mar 2011
    2,247
    On road performance actually. I have quite a distance on road to get to the dirt. I like it from your review so far.
    Thanks..!
    No updates.
    Thanks!
  6. #35
    Nov 2015
    Great White North
    680
    The on road handling is fine. No issues at speed and it is safe.
    I do fear that with extended on-road, higher speed usage, that Terrathon ERT will wear the center lugs down fairly quick, but that is just my opinion.
    So far, I have about 500 miles on it, and the center lugs are just rounded off a little and starting to flatten out.
    There is probably a better ATV tire for on road, long term wear.
    Notice: the Terrathon ERT does not have much rubber in the center of the tire. So when driving straight, the road contact is divided on small areas of the LH and RH center lugs...does that make sense?
    JerseyJeeper and TWilight like this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  7. #36
    Mar 2011
    2,247
    I'll be checking back with you occasionally Thanks
    Notice: the Terrathon ERT does not have much rubber in the center of the tire:
  8. #37
    Nov 2015
    Great White North
    680
    Sounds good.
    I have 2 of these Terrathon ERT tires (one installed on TW, one spare). At 1000 miles, I'll post the tread depth measurements (worn VS. new).
    Thanks!
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  9. #38
    Sand Hollow, ID
    9,412
    Sounds good.
    Thanks!
    Is the spare just in case you get a flat! Giggle
  10. #39
    Nov 2015
    Great White North
    680
    You just crossed the line!
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  11. #40
    Sand Hollow, ID
    9,412
    I kid I kid!
  1. If Rear tire is flat?
    By Phantom99 in forum General Discussion
    Last Post: 07-08-2015, 12:16 AM
  2. Anybody tried the Michelin T63 tires? Front and rear?
    By Flathats in forum Performance and Customization
    Last Post: 06-26-2015, 09:17 PM
  3. HoverBike - No More Flat Tires
    By Fred in forum Off-Topic
    Last Post: 06-18-2015, 06:56 PM
  4. New member: Help witih rear tire flat please
    By Zachary in forum Technical Help
    Last Post: 07-17-2014, 09:32 PM
  5. flat tires on the trail
    By norcaloz in forum General Discussion
    Last Post: 06-29-2014, 01:18 AM
battery
carlisle trail pro
