TW Run Flat Rear Tires!
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Like Tree146Likes
Thread: TW Run Flat Rear Tires!
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    709
    Well, with a little luck, I was able to score 2 Carlisle Terrathon ERT Run Flat Tires (26x8-14) for the rear of my TW. These are 4 ply, 22 psi, real deal run flats.
    My plan is to use the stock rear TW200 wheel + a tube + the Run Flat tires - no idea how these are going to mount up.
    My bro is a service mngr and a modern auto repair / tire shop, so he will be my first stop. His shop has all the equipment for automotive run flat tires.
    Has anyone else in the world of TWs tried this?
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Senior Member wrench-puller's Avatar
    Port McNeill, B.C.
    535
    Run flat.....now that's cool! Now that I have my Maxxis Ceros on my bike I fear the day it goes flat. After the three day mounting ordeal I think I would just sell it as is / where is .
    Are you going to extend your swing arm if the tire mounts ok?
    TWilight and jtomelliott49 like this.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Pleasanton, CA
    4,325
    Very cool, we'll be interested to see how these mount up and perform!
    site:tw200forum.com
    Nov 2015
    Great White North
    709
    No plans to extend the swing arm - yet
    I will drop off the tire / wheel at the shop next week - I will post any progress ASAP.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Nov 2015
    Great White North
    709
    When the rear tire works out (hopeful thinking) - I will be looking for a Run Flat(ish) front tire too. Any ideas?
    jtomelliott49 likes this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Senior Member JagLite's Avatar
    Aug 2010
    Anchorage, Alaska
    519
    Very interesting...
    James
    ______________________
    Attitude =
    The difference between
    Ordeal and Adventure
    Nov 2015
    Great White North
    709
    Dropped the tire / wheel / tube off at the shop - hope to have good news tomorrow!
    Your opinion needed: Should I get this rear tire / wheel balanced or just leave it as is? The TW is no speed machine and I will rarely be taking this on road. Thoughts...?
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,094
    Yes, balance it or add RideOn to it.
    Nov 2015
    Great White North
    709
    The tire is mounted on the wheel! It took extra lube and 70psi to seat the bead.
    The shop had issues seating the bead (took 3 days) but was able to do it without trimming anything off the tire.
    The max pressure needed was 70psi which is quite high. I am using a HD tube and the tire has super thick / super stiff sidewalls, so a high pressure should be ok.
    I'll get it mounted on the bike this weekend and take some pics.
    Thanks for all the help - great info on this forum.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Nov 2015
    Great White North
    709
    Here's how it looks mounted on the rim. Nice ROUND profile, not square at all!
    I'll fit it on the bike this weekend.
    YES - my wife said it is OK to bring tires in the house (because it is below 0F, I didn't want the tire snot freezing in the tire).
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  1. If Rear tire is flat?
    By Phantom99 in forum General Discussion
    Last Post: 07-08-2015, 12:16 AM
  2. Anybody tried the Michelin T63 tires? Front and rear?
    By Flathats in forum Performance and Customization
    Last Post: 06-26-2015, 09:17 PM
  3. HoverBike - No More Flat Tires
    By Fred in forum Off-Topic
    Last Post: 06-18-2015, 06:56 PM
  4. New member: Help witih rear tire flat please
    By Zachary in forum Technical Help
    Last Post: 07-17-2014, 09:32 PM
  5. flat tires on the trail
    By norcaloz in forum General Discussion
    Last Post: 06-29-2014, 01:18 AM
battery
carlisle trail pro
