Mule Nuts? - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Like Tree8Likes
Thread: Mule Nuts?
  1. #21
    Tennessee
    1,170
    Quote Originally Posted by catamount View Post
    I wish! I doubt you'll find such a small pin (M6) as a hitch pin.
    The bolt is small so you'll have to drill it yourself. I cut the head off the bolt and then put it in a vise. Using something sharp and hard like a nail, I'll get an indentation going in the bolt. Then you just drill a straight hole through it.
    Ah my bad. I thought you got ahold of some like that. I dunno about M6 size, but I've got some pretty little ones threaded like that on my lawnmower. The threads run the entire length, though.
    Some things shouldn't be left like you found them.
  2. #22
    Member TWmonster's Avatar
    Sep 2010
    Spokane WA
    50
    Here was my solution: Monsterbolts. Simple allen wrenches, washers, and metric allen bolts. Just JB Welded them all together and shot them with a little spray paint. Way back when Mule was making his Mule Nuts it got a lot of us thinking of our own way to solve the solution. Props to Mule for the original idea WAY back when! Wish the archived site still had pictures and could be searched.
    chainslap likes this.
    My TW is HUNGRY!
    '01 TW200, WPS Handguards, D2moto Foot Pegs, Jimbo's Cafe Fairing, Tusk Handle Bar Risers, Yamaha Rear Rack, 47 Tooth Rear, 3/16 Fuel Filter, Monsterbolts, Monsterbrace, HJC CL-14 Fuse, HJC ACX1, Cortech GX-AIR, RU Outside Teton Gloves
  3. #23
    Senior Member ATXthumper's Avatar
    Aug 2010
    Austin, TX
    231
    Quote Originally Posted by TWmonster View Post
    THESE ARE AWESOME!!
    '01 TW200: Tusk D-Flex Handguards w/ Spoilers, Pro Taper Grips, LEDs in Idiot Lights, Headlight Rockguard, Stearns Seat Pad, Oversized Footpegs and a Loud Ass Horn -SOLD
    '91 TW200: Bone Stock
  5. #24
    Desert, SoCal
    7,375
    My latest tweak of JS5owner's version. The hitch clips stay with the seat:
    Electrical ring terminals crimped to picture wire, then anchored to the seat strap bolt.
    Fred, snowman485 and renny10n like this.
  6. #25
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    ^^^ that is brilliant! must try to copy...
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
  7. #26
    Senior Member Kankujoe's Avatar
    Missouri, West Central
    157
    I like this solution. It will be one of my mods.
    KJ
    2008 Yamaha TW200
    2011 Kawasaki Versys
    2012 Suzuki V-Strom-ADV
    2013 Honda CRF250L
  8. #27
    Member Turwilliger's Avatar
    Nov 2011
    81
    Quote Originally Posted by Kankujoe View Post
    I couldnt find anything at my local Ace hardware but regular bolts with threads from top to bottom. I may fill in the threads with JB Weld and put a rubber grommet on the bike frame to tighten up the hole on the bike frame. Should keep the seat from walking around or clattering.
    As for retaining the pins to the seat, ill probably just use some strong fishing line and small self tapping screws.
    Kcfranqui likes this.
    07 tw200 - 70% offroad useage / barkbuster vps handguards / Emgo trunk box on oem yamaha metal rack / mirror extenders (ebay) / DID 428 v oring chain / jt sprockets 14/47 / pro taper se hi handlebars / pro taper mx synergy dual compound grips / judicious use of black 3m scotchlite reflective tape
  9. #28
    Jun 2011
    Dothan, AL
    1,715
    I think this thread should get pinned.
    jtomelliott49 likes this.
    2005 TW200 (SOLD)
    2013 DR650
  1. I found a 91, but I think the guy is nuts...
    By Tom Bettiker in forum General Discussion
    Last Post: 04-09-2013, 08:02 PM
  2. TW and competition for Mr. Bracket’s moto-mule
    By old white truck in forum TW200 Classifieds
    Last Post: 02-18-2013, 09:52 AM
  3. "Mule" Magnetic Drain Plug
    By Live2Ride in forum Performance and Customization
    Last Post: 05-04-2012, 07:41 PM
  4. TTW200... Yes, I am nuts. Yes, I am new to this forum.
    By morganlowe in forum Performance and Customization
    Last Post: 04-20-2012, 08:26 PM
  5. Mule Logging with the Cycle Rack
    By admiral in forum General Discussion
    Last Post: 10-19-2010, 10:43 AM
arlen ness grips victory vision discount
do mules have nuts
moto-mule on a v-strom
mule hitch pin
mule nuts
mule nuts & seat
mule nuts & seat tw200
mule seat tw200
mules nuts
tw200 forum mule nuts
tw200 mule nuts
tw200 quick releqse seat
