Mule Nuts?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Like Tree9Likes
Thread: Mule Nuts?
    Senior Member catamount's Avatar
    Aug 2010
    Vermont, USA
    314
    On the old forum there was lots of talk of these quick-release seat pins made by forum member "Mule". They were called "Mule Nuts". Does anyone happen to have a photo of what they looked like or worked like?
    I'd like to come up with some sort of quick-release for my seat.
    Thanks!
    Check out my custom TW200 build Hidden Content .
    TTR225 SS header, FMF Turbine Core 2 pipe, EK o-ring chain, 15T front sprocket, 50T rear sprocket, 20W fork oil, Drag Specialities speedometer, Victory Vegas headlight, Acerbis universal supermoto front fender, Vintage Yamaha chrome gas cap, Integrated LED rear tail/turn/brake light, Yamaha Blaster shock, Pro Taper SE ATV High handlebar, Western Powersports off-road handguards, Pro Taper Pillow Top Lite grips, Over-sized foot pegs, Maxxis 6006 front tire, seat cover from eBay seller mac32756.
    Senior Member HenryJ's Avatar
    Oregon, USA
    179
    Quote Originally Posted by catamount View Post
    Thanks!
    I used a 5/8" slack adjuster (truck air brake pin) pin. Drilled and tapped the head end for the piece of threaded stock and drove a roll pin through the cotter pin hole to make a "T" handle. Works great.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Aug 2010
    Vermont, USA
    314
    Quote Originally Posted by HenryJ View Post
    Good plan! It should also work if I just drill a hole in the threaded stock alone, right? Do I need the air brake pin?
    Also, how do you keep it "tight" against the frame to stop the seat from jumping around?
    Oregon, USA
    179
    I have a feeling that a picture might clear up my foggy description.
    - Hidden Content
    Aug 2010
    Vermont, USA
    314
    Thank you! That makes it perfectly clear!
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    Here is my solution - a hitch pin, aptly named: Mule hitch pin! [grin]
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
    Senior Member rm_hm's Avatar
    1,619
    Does the seat wiggle up and down at all with the pin setup when off roading?
    I'm all for not needing tools to get the seat off.
    What would happen if you moved that pin to the end of the bolt and put a flat washer and a spring in between the bike frame and pin?
    Or am I just making things too complicated?
    Anyway... does anyone know what thread size are the seat bolts are ?
    Edit:
    I gave the spring route a run. Worked out fine. But I could see someone dropping the spring and having a loose seat all the way home.
    308
    Quote Originally Posted by Rich View Post
    Does the seat wiggle up and down at all with the pin setup?
    Anyway... what thread size are the seat bolts?
    Rich, for me I like to keep things simple... I've not had a problem with any seat wiggle but I also have the Stearns/Walmart seat cover that I use - it and my butt [grin] keeps it down... I don't know what the size of the seat bolt is, I just took it down to the Ace and matched it up.
    Aug 2010
    Vermont, USA
    314
    Quote Originally Posted by JS5owner View Post
    Yes! These were the photos I saw on the old site. Thanks for re-posting them.
    Also, I think the bolt is a 6 mm x 1mm thread.
    1,619
    I smell a missing link award for someone
    hanknichols21 likes this.
  1. I found a 91, but I think the guy is nuts...
    By Tom Bettiker in forum General Discussion
    Last Post: 04-09-2013, 08:02 PM
  2. TW and competition for Mr. Bracket’s moto-mule
    By old white truck in forum TW200 Classifieds
    Last Post: 02-18-2013, 09:52 AM
  3. "Mule" Magnetic Drain Plug
    By Live2Ride in forum Performance and Customization
    Last Post: 05-04-2012, 07:41 PM
  4. TTW200... Yes, I am nuts. Yes, I am new to this forum.
    By morganlowe in forum Performance and Customization
    Last Post: 04-20-2012, 08:26 PM
  5. Mule Logging with the Cycle Rack
    By admiral in forum General Discussion
    Last Post: 10-19-2010, 10:43 AM
arlen ness grips victory vision discount
do mules have nuts
moto-mule on a v-strom
mule hitch pin
mule nuts
mule nuts & seat
mule nuts & seat tw200
mule seat tw200
mules nuts
tw200 forum mule nuts
tw200 mule nuts
tw200 quick releqse seat
