Added a light.
Results 1 to 6 of 6
Like Tree5Likes
  • 3 Post By Sbungo
  • 1 Post By Devils Advocate
  • 1 Post By Sbungo
Thread: Added a light.
    Junior Member Sbungo's Avatar
    Aug 2015
    Eastern Pa, Berks County
    10
    Added a light.
    Had a trail tech light that I was no longer using. Decided to mount it to the right turn signal. No wiring needed since it has its own on / off switch. All I had to do was run two wires to the battery and splice in an in-line 20 amp fuse.
    Note - not sure why the pic keeps uploading sideways.
    Fred, GTG and jtomelliott49 like this.
    May 2014
    Yooper, MI
    1,493
    Nice. What did you use to mount those up? Do they come with mounting hardware for a round tube, blinker stem or handle bar?
    jtomelliott49 likes this.
    Aug 2015
    10
    It came with a handlebar mount. So mounting onto the turn signal bracket was no problem. Pretty secure too and can be adjusted in all directions.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,486
    How many lumens?. Does it do well at night?. TIA.
    Aug 2015
    10
    I think it's 1,850 lumens. Makes a big difference at night. When I bought it 4-5 years ago there was an option to get the flood light or the spot light. I opted for the flood light and glad that I did. Not real concentrated in one area which is good.
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    709
    Good idea. I did the same thing using a Polaris LED kit - the bracket worked for TW perfectly. 900 Lumens
    I use the LED as my low beam, and the main headlight is HID which is my high beam.
    https://www.rockymountainatvmc.com/p...h-Wire-Harness
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
  1. Added LED light to front of bike today
    By Little General in forum Performance and Customization
    Last Post: 11-17-2014, 05:33 PM
  2. Added one more to the safe!
    By ZDR1 in forum Off-Topic
    Last Post: 10-18-2014, 04:53 PM
  3. trouble with tail light install - DRC Edge Brake Light
    Last Post: 04-20-2012, 07:09 PM
  4. Added features
    By demarko69 in forum Performance and Customization
    Last Post: 07-17-2011, 11:10 AM
