The Famous Storage Tube - Page 3
Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 172
Like Tree75Likes
Thread: The Famous Storage Tube
  1. #21
    Senior Member HenryJ's Avatar
    Oregon, USA
    179
    Quote Originally Posted by bikerjosh View Post
    HenryJ how did you attach your tubes to the cyclerack? Your install looks pretty clean.
    Sorry I missed this post.
    I used a heat gun to form the mounting tabs to the Cyclerack, They are each attached to the rack using three 120lb heavy duty cable ties (Zip-ties).
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
  2. #22
    Senior Member dstock@alaska.net's Avatar
    Fairbanks, Alaska
    238
    That is just way cool, will have to find some.
  3. #23
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by Truelight View Post
    I opted for the top of the rack install, because I wanted two tubes. Your method works great on the left side of the bike, but on the right side the plastic and muffler get in the way.
    So why not mount 3?
    Stephen S.
    '07 TW200:
  5. #24
    Member eaglescall's Avatar
    Sep 2010
    Kirkland, WA
    60
    Lacquer thinner works great to remove the graphics if you have any around. Just a bit on a paper towel and the graphics wipe right off. Be sure to allow your towel to completely dry before you throw it away - don't want any spontaneous combustion in the trash can ruining your day.
  6. #25
    Senior Member Ripshod's Avatar
    Sep 2010
    Knoxville, TN
    140
    That looks like a really handy item. One question though. Can you fit your hand down into the tube to get things out? I assume it has an interior diameter of about 3". Don't know that I can reach into it.
    Youth is wasted on the young.
  7. #26
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,401
    Thats a very good question. Simply put, I don't know. All the stuff I put in the two tubes I use is long enough to reach once the cap is off. If I had to guess, I would say, the bottom of the tube would not be the best place to keep a spare key should you need to make a 'fast exit'. Gerry
    Take care my Friend.........
  8. #27
    Sep 2010
    Knoxville, TN
    140
    What I need is a place to keep the stuff I put in the fairing pocket on the other bike. You know, registration and insurance card, face shield cleaner, tire pressure gauge. It looks like a genius idea but if all that stuff is stuck in the bottom of a 12" tube I might have to get good at doing wheelies to get it out.
    I can see me now on the side of the road: "Okay officer, I'll get my paperwork. Stand aside, please."
  9. #28
    Paradise, Calif.
    3,401
    Perhaps placing your stuff in a large ziplock bag and rolling it up so it slides into the tube but can be easily reached to pull out. Gerry
  10. #29
    Sep 2010
    Knoxville, TN
    140
    I've found my solution to that little problem, posted about it here. I'll probably go ahead and get a couple of the tubes. In fact, I'll probably get a couple of extras because I showed my buddy this thread and now he wants one for his Transalp.
  11. #30
    Senior Member betopimienta's Avatar
    Texas
    158
    I have found that if you have a rear cyclerack you can "mount" the document storage tubes without the use of any extra hardware whatsoever. No cable ties , brackets or bolts were used in the installation of my tubes. And they wont come loose and fall off under normal conditions. Not the prettiest install but hey ,it works! You could even custom trim the large plastic bracket of the storage tube to fit the curve of the cyclerack and make it look nicer.
  1. Storage Options
    By frogman215@hotmail.com in forum General Discussion
    Last Post: 07-05-2015, 12:49 AM
  2. Famous Tool Tubes
    By Drifter in forum General Discussion
    Last Post: 07-01-2013, 04:53 PM
  3. Out of storage
    By Ssokzon in forum Technical Help
    Last Post: 06-20-2013, 10:20 AM
  4. Storage Tube / Fuel Bottle
    By Retrofit in forum Performance and Customization
    Last Post: 04-03-2012, 12:41 AM
  5. Famous TW200
    By n2o2diver in forum General Discussion
    Last Post: 01-12-2012, 11:55 AM
honda ct50 scramble
msr bottle
tw 200 storage
tw 200 storage tube
tw200 forum tube for msr bottle
tw200 moose expedition rack
tw200 moose rear rack
tw200 storage
tw200 storage solutions
tw200 storage tube
tw200 tool tube
yamaha tw200 expedition rack
