trail tech mounts - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree59Likes
Thread: trail tech mounts
  1. #11
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    624
    just finishing some threads. I didi finish the mount and wiring. it all works well and looks good. It was a little tricky to get a pic with all four indicators lit up. The red is an oil pressure light. its a kawi part and works ok. I found a thread adapter to install it in the check port. It works as intended, but when the oil is hot this little motor doesnt develop enough pressure to keep the light out at lower rpms. Im going to install a little switch to bypass the light when Im not using it.
    Untitled by dolphaxel, on Flickr
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. restoration project. mostly complete and collecting miles.
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content
  2. #12
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,247
    Looks nice!
  3. #13
    Member Sathump's Avatar
    Apr 2016
    32
    I should have a vapor by tomorrow
    Has anyone used the handlebar mount that comes in the kit?
    Any reasons why not?
  5. #14
    Nov 2013
    yakima wa.
    624
    i was using the stock trail tech handlebar kit before. It worked well, but I always kinda found it in the way. I wanted to unit further down behind the cowl and didn't need the redundant speedo. for the vapor I believe they make an easy indicator light kit as well. either way their mound works fine I just wanted to clean it up a bit.
  6. #15
    Apr 2012
    Out West
    1,666
    I'm liking the Trail Tech Voyager but it looks like it's black and white I would like to hear what you guys think of these. Love all the mounts you guys made!
    Smitty Blackstone likes this.
    "It's Like Warm Apple Pie"
  7. #16
    Nov 2013
    yakima wa.
    624
    I've put 10k or better on with the voyager. It's a nice unit. The gps feature has bailed me out a few times.
  8. #17
    Apr 2016
    32
    Loctite plus trail tech plastic equals a whole lot of NOPE !
    I'll be making a mount now
    RT emulators 64lb spring 2 turns, .70kgmm springs no spacers, 135mm ATF
    Custom Penske 8975 shock, 750lb spring Hidden Content
    #34 pilot 1 1/2 turns, 3c5-14336-00 needle +2 shims, 130 procycle main, XT225 header & FMF powercore 4
    YZ85 TM chain slider & guide, 15/49, DID 428VX
  9. #18
    12,400
    Mr.Gizmo came from Gerry with a Voyager in place of right side instrument housing while retaining the stock speedometer for redundancy.
    I just cleaned up his prototype mount to place Voyager's face co-planer with speedo housing for a cleaner look. Bracket was simple “L” of bent aluminum plate screwed to OEM housing base with some vibration isolation mounts then securing the Voyager. Indicator lights were relocated near risers below tachometer.
    Mattwings likes this.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  1. New Trail Tech SCMR16 HID
    By Air Biscuit in forum TW200 Classifieds
    Last Post: 09-25-2016, 07:13 PM
  2. Trail Tech Computers?
    By LuvNot in forum General Discussion
    Last Post: 08-03-2015, 05:23 PM
  3. Trail Tech Endurance II Install
    By UUes in forum Performance and Customization
    Last Post: 07-23-2014, 12:10 PM
  4. Mounting a trail tech viper
    By Kcfranqui in forum Performance and Customization
    Last Post: 12-18-2013, 11:22 AM
  5. Vapor Trail Tech
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-21-2012, 01:33 PM
