TTR Case Bolted to A TW Case
Results 1 to 10 of 16
    Poway CA.
    1,927
    The TTR case is on the left and you can see the amount of metal that would need to be removed to install a TTR cylinder in TW cases.
    I used a Dremel and water to keep the bit cool and from clogging up from the hot metal. See the scribe mark along the black paint so I do not take to much off.
    Next a sanding to smooth it out.
    Ronnydog
    Desert, SoCal
    7,375
    Quote Originally Posted by ronnydog View Post
    The TTR case is on the left and you can see the amount of metal that would need to be removed to install a TTR cylinder in TW cases. I do not get the picture loading on this site???????? I do the same thing each time ????????
    [IMG]http://i678.photobucket.com/albums/vv147/ronnydog/PA030367.jpg[IMG]
    http://i678.photobucket.com/albums/v...g/PA030369.jpg
    http://i678.photobucket.com/albums/v...g/PA030371.jpg
    Ronnydog
    Jul 2011
    1,123
    I see what you are doing, and it looks cool, but that doesn't mean I know what you are getting at...
    ITCB
    Devon, England.
    614
    Ronnydog,
    Why are you boring out the TW cases and not using the TTR cases. Maybe I'm missing something but that's what I did. the TW generator side cover with the outrigger bearing fits it no problem.
    10,666
    +1
    The TT-R counterbalancer is different from the TW counterbalancer. If you're using a longer stroke, might want to use the heavier counterbalancer.
    Poway CA.
    1,927
    Quote Originally Posted by uktw125 View Post
    Ronnydog,
    I did it so almost anyone could do this build with there TW motor and not need to buy a TTR. Ya the TTR cases would be the way to go especially because I'm adding a six speed.
    Ronnydog
    Poway CA.
    1,927
    +1
    I have three TTR counterbalances and the weight is different in all of them.
    #1. TTR counterbalance 1 Lb 2.6oz
    #2. TTR counterbalance 1 Lb 2.1oz
    #3. TTR counterbalance 1 Lb 1.9oz
    The TW counterbalance 1 Lb 1.7oz
    The TTR is on the left.
    10,666
    Did you happen to know which TT-R balancer came from what year? I expect the heaviest would provide the smoothest running stroker engine.
    Poway CA.
    1,927
    It looks like the TW has the most weighted offset, not to sure how to say that? If you look at the pics of the counterbalance the weight in the TTR is more in the shaft not in the offset lobe like in the TW.
    Ronnydog
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,395
    Boy oh boy, you have quite a project there. I suspect, at some point you will have quite the trailbike as well. Thanks for all the great pictures and info. Your project will make one helluv a sticking. Gerry
    Take care my Friend.........
  1. Simple gun case mounting
    By rick james in forum Performance and Customization
    Last Post: 05-19-2013, 08:02 PM
  2. Pelican Case Mods
    By Retrofit in forum Performance and Customization
    Last Post: 10-16-2012, 04:17 PM
  3. Carrying case?
    By Woodi23 in forum General Discussion
    Last Post: 09-17-2012, 10:57 AM
  4. New Pelican Case
    By Larry in forum Performance and Customization
    Last Post: 04-21-2011, 08:09 AM
  5. Oil in Magneto Case
    By TWAlan in forum Technical Help
    Last Post: 10-31-2010, 08:27 PM
install xt350 cylinder on sr250 case
