Progression of Daryl, the Ultimate Survival bike - Page 3
Results 21 to 30 of 37
Like Tree64Likes
Thread: Progression of Daryl, the Ultimate Survival bike
  1. #21
    Jun 2014
    Bel Air Maryland
    3,192
    Quote Originally Posted by Boedy View Post
    How you like me new White Bros. style supertrapp exhaust?
    Sent from my iPhone using Tapatalk Pro
    How well does your stove work?
    littletommy likes this.
    Rick
  2. #22
    Member Boedy's Avatar
    Sep 2011
    Atlanta, GA
    71
    Well, it's louder than I wanted, but 'ya know. My brother and I thought that maybe the exhaust was causing it to not rev out, so I had this slip on for a YZ426 laying around for another project, so I just loped off the stock muffler, and welded this up. I think it looks great, and I've ridden it briefly, and it seems better, but it's too early to tell.
    littletommy and TopPredator like this.
  3. #23
    Sep 2011
    Atlanta, GA
    71
    Oh, wait, you said stove. Great.
  5. #24
    Ken
    Ken is online now
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    616
    My experience: At high speeds lack of fuel will cause a thumping until you slow a bit and it will run fine. We experienced this on a trip when a clogged fuel sock caused this. My TW was doing this due to a leaking air boot allowing extra air leaning it out. I think a bigger jet may help some. Air flow around the filter also affects this. You may end up with too much flow for the size engine with no beneficial gains. Here is an untested idea I have had. With no air box you still need some restriction. I was thinking about a thin metal disk which would fit in the filter tube inlet. Drill lots of holes in it. Too rich, add more holes. Too lean, try a new disk put a few less holes. Just an idea, not tested.
    TopPredator likes this.
  6. #25
    Ken
    Ken is online now
    Aug 2016
    Houston, Texas
    616
    Some have stated the rev limiting factor on the TW is the cam. I don't know this for sure or the best cam for the job. This may be top secret. I'm currently tinkering with a cam mod but haven't completed my set up.
  7. #26
    Sep 2011
    Atlanta, GA
    71
    So, I've got Darryl running pretty sweet now. Opening up the exhaust made a world of difference, I've got the jetting dialed in, and put Seafoam in the gas tank to eat the carbon off the piston and valves and it keeps getting better and better. Last night I figured out a way to mount my newest attempt at a reasonably cool seat. It's the pilon or passenger seat for a Harley Sportster. So far, it's my best attempt. Whatcha think?
  8. #27
    Senior Member old w/2 many guns & bikes's Avatar
    Apr 2014
    491
    Looks like it was designed for it with that tank.
  9. #28
    Spokane, Washington
    14,192
    What TW part got painted on in the grass? Just curious...
    Dryden-Tdub and Rockit like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    If one small act of kindness can change someone's day for the better, think about the difference you could make over the course of a lifetime. Hidden Content
    John 10:10 I am come (Jesus) that they might have life, and that they might have it more abundantly.
  10. #29
    Sep 2011
    Atlanta, GA
    71
    Ha! That would be the seat pan.
  11. #30
    Sep 2011
    Atlanta, GA
    71
    Okay, so I had the bike running really well. Long short of it is: it all of the sudden stopped pulling fuel from the carb and into the motor. Plug is completely dry, compression is at 150psi, and the motor will fire right up and run as long as I am fluttering my hand over the carb intake to get it to suck up the fuel. I've completely disassembled and cleaned the carb. Never seen anything like this before. Fuel is in the carb, carb is clean, but engine won't pull the fuel in.
    Any ideas?
    Since I was planning on replacing the carb anyway, I went ahead and ordered a Mikuni TM28-1 to slap on it. But I'm still interested if anyone else has had anything like this happen to them. I don't have a clue. It was running great, then...nothing
  1. Triumph Unveils Ultimate Winter Bike
    By littletommy in forum Other Bikes
    Last Post: 11-22-2016, 05:38 PM
  2. Survival Rifle for the TW
    By TopPredator in forum General Discussion
    Last Post: 02-11-2015, 08:23 PM
  3. Survival bike anyone?
    By rivershot in forum Other Bikes
    Last Post: 02-01-2015, 11:11 AM
  4. Ultimate sin.
    By turborob in forum Off-Topic
    Last Post: 02-18-2014, 02:12 PM
  5. Java^TW's Intro/Progression Thread
    By Java^TW in forum General Discussion
    Last Post: 02-02-2013, 10:21 AM
