#$%^&$$$ tires
Results 1 to 10 of 12
Like Tree28Likes
Thread: #$%^&$$$ tires
    Member neckless's Avatar
    Dec 2015
    dryden ont canada
    93
    #$%^&$$$ tires
    https://fortnine.ca/en/cst-cu07-behe...port-rear-tire ..... think iam gona buy thes tires what u think
    jtomelliott49 likes this.
    12,823
    "Page Not Found"
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
    Dec 2015
    dryden ont canada
    93
    dam computers ..... its a bridgestone TW52.... and a cst cu07 behemoth atv tire i try to get pics...
    Member EnduroRdr's Avatar
    Jun 2011
    Denham Springs LA
    79
    I think he meant this link:
    https://fortnine.ca/en/bridgestone-t...port-rear-tire
    I think that tire should be fine.
    It reminds me of the shinko 244
    1989 TW200 - replaced almost everything!
    Spokane, Washington
    14,507
    There may be better tires out there for the same money...
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    12,823
    There certainly are better tires out there for less money in my opinion.
    The cst cu07 in a 26x9x14 will likely require extending the swing arm for good clearance. I would suggest budgeting a bigger rear sprocket along with the swing arm extension should you order the 27 inch tall CST.
    A Duro Powergrip in a 26x8x14 should set you back less than $100 & will fit w/o swing arm modifications and the resultant drive ratio changes are only ~ 26.5/25.5, or ~4% more street oriented than stock. I would still go up 10% or so on rear sprocket's tooth count to overcome parasitic drag and rotational inertia of the heavier tire, as well as to get a bit of torque multiplication to better utilize that extra traction if you do get into the loose soil conditions that justify an ATV tire.
    As far as the front tire goes I always question people's choice of a MX style rear tire designed to churn and provide forward thrust while spinning relative to the ground over a tire designed for cornering and lateral stability while hooked up. My TW is not front wheel drive and as such never churns generating forward thrust. Knobby fronts just give a knobby ride in my opinion.
    To each their own, but I am just responding to the OP's "what u think".
    jtomelliott49 and littletommy like this.
    Active Thumpers:
    1981 KDX175 Enduro
    1982 YZ250G MX
    Dec 2015
    dryden ont canada
    93
    thanks for the input,,, i think i will take another look that rear tire is like 10lbs heaver
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    765
    One thing for sure you can't beat Fortnine for prices and service in Canada
    grewen and jtomelliott49 like this.
    Nov 2016
    So. California, inland empire
    267
    I really don't have a problem with the rear TW34. It seems to work pretty well.
    I know it's not as aggressive looking as the most atv tires but the big weight difference has kept me from pursuing the trailer, or other 12", rear wheel/tire combo. But you always want to do more with these things and tires can make a big difference.
    I have the sr241 front and a stock front TW31 and it's a very noticeable improvement, to me, between the two on and off road. I'd use that front with whatever rear you went with.
    Dec 2015
    dryden ont canada
    93
    great info....i think i will get a 241 and a oem rear tire................and look at a trailer wheel mod and just change it when i want to play in the swamp.....
    littletommy and Dryden-Tdub like this.
  1. Honda Rebel gets an upgrade. 300 & 500cc's and Fat Tires.
    By MidnightRider in forum Other Bikes
    Last Post: 05-07-2017, 09:26 AM
  2. Replies: 14
    Last Post: 06-05-2016, 11:00 PM
  3. FS - Trailwing 203 & 204 tires - NEW
    By orchemo in forum TW200 Classifieds
    Last Post: 11-15-2015, 01:38 AM
  4. Brand new F&R Bridgestone tires for sale !!
    By gregfish in forum TW200 Classifieds
    Last Post: 05-09-2015, 01:27 PM
  5. ^&$&%^&&&**^%%^& professional drivers!
    By qwerty in forum Off-Topic
    Last Post: 01-31-2015, 07:10 PM
