Another Removable Swingarm Extension Concept - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree42Likes
Thread: Another Removable Swingarm Extension Concept
  1. #11
    12,804
    My apologies.
    Yes, I can see now how the shear stress is rather well contained by the design of the backing plates.
    I just took a quick look, imagined the loading and did not consider the interplay of all the depicted parts.
    Having worked for awhile in a materials testing lab where we would bend, crush and pull all sorts of things apart I tend to jump to conclusions on just how easy things can be made to fail. I guess that includes failed assumptions too.
    Nice design. So if you get the water jet would you cut me a set?
    JerseyJeeper and TW-Brian like this.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  2. #12
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,271
    Thanks Fred. You're a smart guy. I was afraid (petrified) you found something I missed, but I would have been glad to be caught if it was a mistake. If anyone would see an issue it would be you and a few others here (not naming names, there are to many and I would not want to leave anyone out). This place is loaded with talent for sure.
    I'm considering asking our engineer if he has CNC software for waterjet machines that he might let me use. The software i use does not seem to have the correct file export. It does 3D printing very well though.
    My apologies.
    TW-Brian likes this.
  3. #13
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC.. 1957 km from moab
    1,428
    looks like it maybe kind of heavy, any ideas of what it might weigh?
    Greg
    2014 TW200
    2016 bolt
    1981 honda ct110
    1973 honda ct90
  5. #14
    Senior Member tree.bobby's Avatar
    Apr 2016
    Yakima, WA
    124
    If it works add me to the order list. I have been scrounging the internet far and wide for bolt on solution but of course there is none... at least from my google searching.
    Spawner likes this.
  6. #15
    Mar 2011
    2,271
    Quote Originally Posted by grewen View Post
    No idea on total weight, you can use the table below. True, "un-sprung weight" is/can be an issue for suspension performance. At the speeds we travel, at least me i'm not sure it would matter. In our case, after adding a giant tire, trailer wheel etc the weight is up over stock.
    I already figured a way to use a little less steel but I wasn't going to draw it again unless I had too.
    Nominal Size Thickness (inches) Weight (lb/ft2)
    1/4 10.20
    5/16 12.75
    3/8 15.30
    7/16 17.85
    grewen likes this.
  7. #16
    Oct 2014
    1,428
    That's a good mental exercise grewen. Why not take the approximate surface area off all the parts times the approximate thickness to get the approximate volume, then multiply by the steel's density to get a weight estimate?
    thanks Fred, that was helpful
    Spawner likes this.
    Greg
    2014 TW200
    2016 bolt
    1981 honda ct110
    1973 honda ct90
  8. #17
    Apr 2012
    Out West
    1,732
    Both of the submitted designs look great and are very sturdy from what I can see but it looks like we are talking about more than a 2" extension here which to me anything over 2" is too much. The stock swingarm slot allows us to move the wheel back 1.5" (aprx) by using a slightly longer chain and possibly a slack tensioner (to compensate for the lack of chain adjustment with the wheel at the back of the axle slot) this will accommodate any ATV tire I would run, There is probably room to lengthen the stock axle slot by say 1/8" possibly a little more giving us close to 1.75" extension with only a longer chain.
    "It's Like Warm Apple Pie"
  9. #18
    Pleasanton, CA
    4,370
    Quote Originally Posted by PlacerLode View Post
    Fortunately, I caught my development team just as they were packing away their wooden blocks and colored markers. I issued them a final challenge - "The customer wants a shorter one!".
    After long hours of brainstorming, and running endless computer simulations and finite element analyses, they came up with what I feel is an elegant solution that the marketing team has dubbed the SSRMTWSAE (Super Short Removable Minimalistic TW SwingArm Extender)! Kinda catchy, huh?
    The following computer generated rendering illustrates the SSRMTWSAE superimposed (in Red) over the original design.
    site:tw200forum.com
  10. #19
    Mar 2011
    2,271
    Awesome! I know a great patent lawyer!
  1. Swingarm Extension - Removeable
    By JerseyJeeper in forum Performance and Customization
    Last Post: 03-10-2017, 05:01 AM
  2. Swingarm Extension - Removeable
    By JerseyJeeper in forum Technical Help
    Last Post: 03-09-2017, 02:00 PM
  3. Swingarm extension
    By TWGIRL in forum TW200 Classifieds
    Last Post: 08-24-2014, 08:01 PM
  4. Swingarm extension pieces.
    By Trikstr in forum Performance and Customization
    Last Post: 05-23-2014, 05:50 PM
