07 GSXR 1000 exhaust on Tw200
Results 1 to 4 of 4
Like Tree12Likes
  • 2 Post By kmxman
  • 4 Post By kmxman
  • 3 Post By methamphetasaur
  • 3 Post By kmxman
Thread: 07 GSXR 1000 exhaust on Tw200
    Junior Member kmxman's Avatar
    Jan 2012
    15
    I was watching the DR650 crowd get into the GSXR exhaust craze so I did it as well. Cause you know if someone else can.....DSC07380.JPGDSC07381.JPGDSC07382.JPGDSC07383.JPG
    Ken and TopPredator like this.
    Jan 2012
    15
    It runs awesome. Sounds even better!!
    To mount it I cut about a inch off the top of the RH can mount bracket and used 2, 1/4 inch bolts and a peice of flat metal to connect to the original exhaust mounting bolt then used a 1/4 inch plate that i cut out to fit the three exhaut pipe mounts and used 1 1/4 pipe from the header to the GSXR muffler. Couple of hours and cheap exhaust that requires no maintenance.
    I have lightened flywheel, ported head, TM28 carb (see my previous posting for jetting specs), High compression piston, Yamaha '84 trimoto 200E oil filter (reusable metal screen type).
    Enjoy.... I would to if it would stop snowing in Calgary
    Happy St Patricks day
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Phoenix
    981
    Video?
    Jan 2012
    15
    Tomorrow, I have to head to work.
  1. Baja 1000 on a TW200
    By Ken in forum General Discussion
    Last Post: 03-07-2017, 08:34 AM
  2. Stock TW200 Exhaust
    By TWightlightZone in forum TW200 Classifieds
    Last Post: 03-06-2017, 11:59 AM
  3. 2017 V-Strom 1000 & V-Strom 1000 Suzuki Workhorses
    By littletommy in forum Other Bikes
    Last Post: 10-06-2016, 01:54 PM
  4. Replies: 10
    Last Post: 12-23-2014, 05:30 AM
  5. 95 TW200 $1000
    By PEEBALLS in forum TW200 Classifieds
    Last Post: 12-20-2011, 02:16 PM
