Key ignition switch to Toggle switch - Anyone do this?
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree50Likes
Thread: Key ignition switch to Toggle switch - Anyone do this?
    Senior Member Skin Walker's Avatar
    Nov 2015
    319
    The project bike that seems to be going on forever, the previous owner obviously lost his key and rammed a screw driver in the key-hole torquing it to the "on" position.
    The bike seemed to be in the always On position and would thus, never keep a charged battery.
    The dude I bought the bike from filled the broke keyhole with some kind of black hard rubber sealant.
    Since the bike I am reworking is strictly intended to be off road in the bush riding, I prefer to just have an ON / OFF toggle switch. Anyone ever do this?
    Check this out...
    There is no need for this bike to have keyed protection and I am not inclined to pay for that expensive keyed ignition switch - unless there is an el' cheapo alternative.
    SW
    Ken, Smitty Blackstone and Fred like this.
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Ken
    Ken is online now
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    616
    I have one bike which self hotwired itself so I put a battery disconnect on it. My problem is that you can disconnect the whole switch and it will still start. You can get cheap ebay key switches for as low as $3.00. I just looked. You could frame mount etc if it doesn't fit perfectly. That is cheaper than a toggle I believe.
    Smitty Blackstone likes this.
    Nov 2015
    319
    Yeah, I'm thinking of just an On/Off switch.. I don't mind spending some money, just not $130 bucks.
    It's a 1993. The ones for 40-50 bucks are for the later models on ebay.
    The wiring plug is red rectangular with 3 pins.
    Ken likes this.
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    275
    Mine is via a toggle switch. All it does is activate the head light and tail light on mine (Or all the other electronics besides the ignition if you have horn, turn signals, starter relay circuit, etc)...The bar mounted kill switch allows the engine to run or stop. I am kick start only.
    Ken likes this.
    Apr 2013
    299
    on a drum brake model i fitted a switch on the underneath of the right side of the air box where the CDI is, i did it as a security kill switch because the bike would start with any key,
    i found these on ebay, fitted quite a few so far, the seem ok, only 1 persons broke, but i think that ewas more him than the lock, well worth the money. the plug is the same for early models, but needs cutting for disc TW.
    Motorcycle Ignition Ignitor Key Switch For YAMAHA YBR125 YBR 125 2002-2013 New
    littletommy and Fred like this.
    Junior Member IreCraEra's Avatar
    Aug 2016
    Labrador, Kanucastan
    10
    Quote Originally Posted by Skin Walker View Post
    Just get a DPDT switch and wire it like below. Then it will work just like a stock switch.... and if you want to get really fancy (and make your life a million times easier) make sure you cut the plug and wires off of your FUBAR'd switch and solder/heat shrink them onto the DPDT switch so that you can just plug it into your harness.
    Hope this helps
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    709
    I like the idea of the TW w/o a key - just a toggle switch. Should be an easy wire up looking at the schematic.
    littletommy likes this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Nov 2015
    319
    Thank you very much!!!!!!!
    I am going to give that a shot - I prefer that!
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Member Sathump's Avatar
    Apr 2016
    32
    I'm planning on deleting the key switch and replacing it with a switch from a WR450
    Also I'm going to use a WR type start switch
    I trying to make the front as clean and open as possible
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    720
    Wow. Wish I lived in an area where I could trust my bikes to not "walk away".
    I drove all day to Tennessee to ride with some forum folks a couple of years ago. Got there and realized I'd left the key at home. After some frantic calls and internet searches, we were able to hot wire a toggle switch into place that worked perfectly. I still carry it on the bike just in case I lose a key.
    littletommy and admiral like this.
    My 2-Wheel Babies: 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2011 Genuine Scooter Co Blur 220i - 1999 Yamaha TW200
  1. Wanted: Switch with key.
    By Dell in forum TW200 Classifieds
    Last Post: 07-15-2016, 11:29 PM
  2. Ignition Switch and Key 2005 TW
    By scottginmexico in forum TW200 Classifieds
    Last Post: 09-17-2013, 08:38 AM
  3. In need of tw ignition switch and key
    By andrewsclues in forum TW200 Classifieds
    Last Post: 10-15-2012, 07:01 PM
  4. Toggle Switch Panel
    By ronnydog in forum Performance and Customization
    Last Post: 09-30-2011, 11:20 PM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
do you need a key ignition when using a toggle switch ignition board
