ISO: Full LED Turn signal set up for 2003 TW200 - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Like Tree21Likes
Thread: ISO: Full LED Turn signal set up for 2003 TW200
  1. #11
    Senior Member Iaintlikeu's Avatar
    Apr 2016
    Elizabeth Pa 15037
    114
    littletommy likes this.
  2. #12
    Apr 2016
    Elizabeth Pa 15037
    114
  3. #13
    Apr 2016
    Elizabeth Pa 15037
    114
    This is what I used,the taillight bracket almost mounts perfectly,I just had to drill the one hole wider to make fit.
    littletommy and Rockit like this.
  5. #14
    Senior Member mckee1710's Avatar
    Aug 2015
    Gainesville, FL
    112
    Installing the diode will restore the functionality of your indicator light on the dash. Check my previous post for the link of the one I used, or feel free to seek out another
    2012 TDub - Cycra handguards w/ LED turn signals, WR250 shorty levers, custom high fender, Tusk 30mm bar risers, Krator footpegs, SeatConcepts, Yamaha rack, integrated LED tail light, 5500 LM H4 LED headlamp, DID 428 X-ring, XT225 stainless header, DG-O exhaust, 130 main, 0.04" needle shim, slide drilled 1/16", pilot 2.25 turns out
  6. #15
    Member BigJimmyW13's Avatar
    Jul 2012
    56
    deleted
  7. #16
    Apr 2016
    Elizabeth Pa 15037
    114
    bought on ebay
  8. #17
    Jul 2012
    56
    deleted
  9. #18
    Jul 2012
    56
    deleted
  10. #19
    Jul 2012
    56
    deleted
  11. #20
    Senior Member lugnut's Avatar
    Apr 2017
    alliance ohio
    118
    I just ordered 1157 LED bulbs for mine to make them brighter and 1156 LED bulbs for the rear. I do not need to put resisters in or change the flasher. I should have them by this weekend and will update you all on how much brighter the LED's are.
  1. LED turn signal flasher, new
    By SportsterDoc in forum TW200 Classifieds
    Last Post: 04-08-2017, 08:44 AM
  2. LED Turn Signal FLasher
    By EWB in forum Technical Help
    Last Post: 02-03-2017, 04:57 PM
  3. LED turn signal problem
    By swmotdub200 in forum Technical Help
    Last Post: 06-30-2014, 07:18 AM
  4. LED turn signal problems.
    By howardgene63 in forum Technical Help
    Last Post: 05-26-2014, 06:56 PM
  5. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
