Raptor 250 Carb on a Tw?
Results 1 to 10 of 14
Like Tree42Likes
Thread: Raptor 250 Carb on a Tw?
    Poway CA.
    1,942
    I am trying a raptor 250 carburetor on my TW. Looks like it will be the right size, right height and seems to fit well . I'm using A TTR 225 intake manifold not sure how to mount a airbox tube from the carb to air box. The OD of the Raptor carb is 52mm.IMG_2133.JPGIMG_2134.JPGIMG_2136.JPGIMG_2139.JPG
    Purple, joeband, elime and 4 others like this.
    Poway CA.
    1,942
    Ken, jtomelliott49 and littletommy like this.
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,247
    Very interesting. Look at the military silicone hose on eBay it may be available in the correct ID. It may be a canadate for the intake but how to terminate at the air box?... some type of flange will be needed. It's always the intake that's a pita!
    As it turns out I'm in the same boat as you. I picked up a ttr225 yesterday with an aftermarket china carb on it but that bike rocks. It had my 290pd ass wheeling wheelies all over, very easily. But there is no intake hose to the air box. There is crappy foam tyewrapped to the carbs intake bell. I need to solve the same issue as you.. if I find anything acceptable I'll post up here for you.
    I couldn't help but notice your oil bypass (and hardwood garage floor!). I like that bypass valve!. Do you have a thread on your cooling system?
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    624
    I could be forgetting, but isn't that motor the 250cc? I'm trying to remember if that's the 74mm re-sleeve job you had.
    Ken and jtomelliott49 like this.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. restoration project. mostly complete and collecting miles.
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content
    Feb 2013
    Missoula, MT
    819
    Pardon my ignorance but is the 250 Carb a "pumper" as opposed to a constant velocity carb? I have always thought the TW needed a pumper. I have one of the $20.00 Chinese carbs but have not put it on. My Tw is running too good to mess with.
    jbfla, admiral, elime and 2 others like this.
    5,857
    Quote Originally Posted by fishguy View Post
    I hate when that happens!
    Poway CA.
    1,942
    Quote Originally Posted by vanillagorilla1 View Post
    Its 71mm piston and a 62mm stroked crank - 245cc. If you look close below the cylinder ther is a 2mm shim.
    ronnydog
    JerseyJeeper and littletommy like this.
    Poway CA.
    1,942
    No the carb is not a pumper.
    Ken and littletommy like this.
    Poway CA.
    1,942
    Quote Originally Posted by JerseyJeeper View Post
    HURRICANE Oil Cooler with SPAL Cooling Fan Install Is from the old forum
    Mr Gizmo had a few good ideas. He said the XT225 air boot will fit the Raptor carb and the splice it with the TW boot.
    ronnydog
    5,857
    What did the 62mm crank come out of ? Did it fit in with out modifications ?
    littletommy likes this.
  1. Raptor 80 for my son's 11th birthday
    By SickPuppy76 in forum General Discussion
    Last Post: 04-02-2017, 05:57 PM
  2. Replies: 3
    Last Post: 08-17-2014, 02:47 PM
  3. Raptor 250 rear shock
    By MCC1776 in forum General Discussion
    Last Post: 02-07-2014, 09:08 PM
  4. Tw225/250
    By kdick91 in forum Technical Help
    Last Post: 08-27-2013, 09:48 PM
  5. 2013 XT-250?
    By NumberThree in forum Off-Topic
    Last Post: 06-12-2013, 10:13 AM
