Installing a Clarke XT225 tank - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Like Tree10Likes
Thread: Installing a Clarke XT225 tank
  1. #11
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Glad I could help out, Guitarman. Our installs look darn near identical. I like your hockey puck solution to the front mount - That looks really good. The only other thing I did differently, that folks can consider, is that I just pushed my seat down in the middle (while installing it) and got it to hook on to the stock location (rather than trimming the seat and hooking in the higher spot)...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
  2. #12
    Senior Member Guitarman's Avatar
    Jan 2012
    Trois-Rivieres, Canada
    167
    You must be a really strong fellow! I didn't even think of pushing it all the way down like you did. I'll give it a try next time I remove the seat. BTW, you don't absolutely need to cut a notch in the seat. Using a shorter bolt to hold the brackets would have solved the issue... It's definitely possible to install that tank without having to cut anything on your bike but the side covers.
    On a side note, I went for my first 30 miles ride with the new tank this morning and I can tell you that it feels like it was made for this bike. No wiggling, buzzing, rattling or discomfort. I was really glad to see the tank almost still topped off went I arrived at work!
  3. #13
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,419
    Great Job on the install and presentation. Thanks. Gerry
    Take care my Friend.........
  5. #14
    Member Splinter's Avatar
    High Desert, SoCal
    95
    Guitarman, the hockey puck idea is freakin outstanding! I just got done throwing a metal XT350 tank on mine and the front of the tank wobbles some when I am actually moving it by hand, not when riding though (did not notice any movement anyway). Hope you don't mind but I totally intend to plagiarize your puck idea. Great Job!!
  6. #15
    Jan 2012
    167
    Thank you guys! ;-)
    Splinter, go for it! That's the reason why I shared it with you. :-)
  7. #16
    Member brent morley's Avatar
    Feb 2012
    Dayton Tenn.
    57
    Quote Originally Posted by Guitarman View Post
    10. Cut your side covers so they fit and compliment your new installation (I used tin snip). Drill two small holes, one on each covers, where they meet the frame and zip tie them in place so they won't fly while cruising on the highway (thank you lzrdbrth for the suggestion, I just red your post this morning about your experience)
    11. Install your stock petcock. It will fit, but it's a tight fit.
    12. Put your seat back on and take care to slip the tab under your new bracket
    Voila! You can now enjoy your ride again without having to fuel four times a day ;-)
    If you want your installation to be perfect, you will need handlebar risers or your stock bar will hit the tank at full turn.
    I insist on risers because I first installed a Protaper ATV High bar and had the same problem, the base of the bars (where it bolt to the triple tree) would hit the tank. I was lucky I had some risers on another bike that I could use. Problem solved.
    I will try the setup as it is now and see if I like it. The bar sit pretty high and I'm a bit worried about the cables I had to reroute. They seem ok but I'll definitely keep a good eye on them in search of any premature wear. There is no binding as I call tell, but they are surely tighter than they were before.
    I'll keep you updated on that.
    How much more gas does your new tank hold?
    I got granny gear haha...
  8. #17
    Member shiftline's Avatar
    Apr 2012
    B.C. Canada
    97
    When installing the TW petcock onto the tank do you use that rubber gasket that came with the clarke tank or remove it?
  9. #18
    Jan 2012
    167
    The tank can hold 4.0 gallons, but it not all available due to the tank design. My rough estimate is that there is only about 3.0 to 3.5 gallons which can be used.
    Yes I used the rubber gasket that came with the tank.
  10. #19
    Apr 2012
    B.C. Canada
    97
    Excellent tutorial, the hockey pucks work perfectly.
    When you put the seat back on did it still hook under at the front or does it just float there now?
  11. #20
    Junior Member peraevum's Avatar
    Jan 2012
    Chicago, IL
    14
    Anyone ridden their Clarke XT225 tank from full to reserve to empty yet? Just curious about the estimated miles you guys are getting out of each full tank. I'm at about 80 miles on my tank and it looks like there's still quite a bit of fuel in there. It will be interesting to compare how much more the Clarke XT225 tanks get vs. the Clarke TW200 tanks.
  1. XT225 Tank
    By r80rt in forum Performance and Customization
    Last Post: 05-09-2016, 03:57 PM
  2. very nice 2007 xt225 fuel tank with shrouds
    By josh in forum TW200 Classifieds
    Last Post: 02-18-2013, 06:59 PM
  3. XT225 Tank for Brock
    Last Post: 01-13-2013, 11:11 AM
  4. FS: Clarke XT225 4.1 gal gas tank
    By d-nix in forum TW200 Classifieds
    Last Post: 12-09-2012, 09:38 PM
  5. Clarke Tank Fit
    By ldw72120 in forum Technical Help
    Last Post: 07-01-2012, 03:18 PM
clarke xt225 tank
modifying xt225 clarke tank
tw200 clarke xt225 tank
tw200 fuel tank
tw200 xt225 clarke tank
tw200 xt225 tank
which xt gas tank
xt225 clarke tank
xt225 gas tank
xt225 tank
xt225 tank on tw200
yamaha xt225 gas tank
