Luggage rack choices - Page 22
Page 22 of 22 FirstFirst ... 12202122
Results 211 to 220 of 220
Like Tree110Likes
Thread: Luggage rack choices
  1. #211
    Member ETAV8R's Avatar
    Aug 2014
    87
    Anymore pics of the manracks rear bbq? Looks pretty neat and competitive against the CR.
  2. #212
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    I have a man rack,its just plain flat one....made very well
    I want to give my wife my rack and buy the new bbq man rack with rotopax bracket. What box fits on these brackets?
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
  3. #213
    Senior Member Elvesus's Avatar
    Jun 2015
    Nanaimo BC
    113
    I'm interested in the Manracks bbq rack too. I've noticed in some of the pics on the Manracks site that the forward mounts under the seat cause the back of the seat to not sit properly (looks like it sits ~1/2" high). For those that have that rack, has it been a problem?
    John in Nanaimo
    2013 TW200 - with Shinko 241 front tire, Rox 2" anti-vibe risers, Polisport Touquet handguards
  5. #214
    Mar 2015
    Ynys Môn
    2,337
    I have the basic Manrack on my bike, and I doubt very much that the fitting is going to be different with the BBQ rack as far as the seat is concerned. The fit to the seat is close, to within a quarter of an inch, but that’s what I like about Manracks – the expression “snug” springs to mind, but it will not touch or otherwise interfere with the seat, neither the back, nor to the sides.
    Don’t know what pic you’re referring to when you say “(looks like it sits ~1/2" high)” but I can assure you that in reality that is not the case – the mounting plate that goes under the seat is only a few mill thick, and slips in there without noticing.
    As to the question of “What box fits on these brackets?” – the added bracket you refer to is for the “Rotopax gas can” - Fuel Packs - and I would suggest that you restrict yourself to the one gallon pack. Although these Manracks are pretty tough, the max 4 gal can would put an unbearable strain on it.
    Rotopax gas cans are a widely used industry standard, and the Manracks BBQ rack comes with the Rotopax mounting base plate already welded on.
    As this Rotopax base plate is fitted flush to the Manrack, you can use any top box you wish too, as it will not interfere with the top box, or with its fittings. Should you require a Rotopax fuel pack instead of a top box, simply remove the box, fix on the Rotopax, and you get the best of both worlds …..
    littletommy, Elvesus and lugnut like this.
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
  6. #215
    Junior Member LarryT's Avatar
    Aug 2016
    1
    I bought one of these front racks from a guy on eBay.
    Yamaha TW200 Front Carry Rack Motorcycle | eBay
    It seems well made and I had it installed in about 10 minutes. I really like it. I have one of the big *Cycle Racks* racks mounted on the back behind the seat, but since I put this front one on, I find myself putting all my misc crap on it now. Makes it easy to see if my goodies are about to fall off or are still there and going to make it home with me.. lol
    littletommy and Yam200 like this.
  7. #216
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,486
    Well , let's see some pics of your rack / luggage system in action , may help riders make decisions. TIA
    littletommy likes this.
  8. #217
    Member BigJimmyW13's Avatar
    Jul 2012
    North of St Louis, in Illinois
    42
    Sooooo.... ManRack or CycleRack?.... I thought I knew I was getting a CycleRack at first, but now I'm thinking maybe a ManRack? Which is bigger? The CycleRack or the ManRack BBQ?
    Current Stable:
    2003 Yamaha TW200 - running and on the road
    1981 Yamaha XS650 (heavily modified) - not running at the moment, again
    1996 Honda VT1100 ACE - running and on the road
    1986 Harley Evo hardtail (custom title frame) - Not running at the moment
  9. #218
    Member Yam200's Avatar
    Nov 2016
    33
    LarryT: Looks like an interesting alu rack. Can you post some pictures / measurements / mounting points? Seems like a prototype / one-of-a-kind rack. Possibly a DIY project with rivets and no welding required?
  10. #219
    Member Lynlee's Avatar
    Mar 2017
    San Diego
    34
    Not sure of the best place to post this, but here is a pic of how I am using my CycleRack rear rack, I have the pannier plates as well.
    I already had Givi waterproof saddle bags and the Givi Treker 42liter case for my BMW, so I simply got a Givi monokey universal mounting plate ($62) which attached to the Cyclerack rear rack, thus allowing me to easily move the top box from one bike to the other. I gotta say the box looks really big on the TW. As you can see there is room to add more luggage on the back of the seat. What a pack mule!
    littletommy and ben2go like this.
  11. #220
    Mar 2015
    Ynys Môn
    2,337
    Quote Originally Posted by BigJimmyW13 View Post
    The Cyclerack is bigger, but not necessarily more load bearing, just wider
    If you’re planning to move home, I’d put the sleeping bag on the rack, and the kitchen sink on the rear seat - (you get the idea)
    They’re both good racks (I have the Manrack), and with good customer service from both parties – though the Cyclerack is often over-loaded simply because of its size – human error
    The Manrack tucks nicely to the bike, and is less likely to fail simply because it doesn’t lend itself to “overloading”
    Favouritism of course, because I made my choice – now you have to make yours …..
    littletommy and BigJimmyW13 like this.
  1. Stock luggage rack on Tw200
    By TdubOhio in forum Technical Help
    Last Post: 07-11-2016, 10:43 AM
  2. Helmet Choices????
    By TuggerHiller in forum General Discussion
    Last Post: 09-05-2013, 10:51 PM
  3. Luggage rack for sale
    By Woodi23 in forum TW200 Classifieds
    Last Post: 04-09-2013, 08:44 PM
  4. Luggage Rack WTB
    By JRD in forum TW200 Classifieds
    Last Post: 10-01-2012, 08:14 AM
  5. Purchasing Choices
    By Kestrel in forum General Discussion
    Last Post: 04-26-2011, 02:25 AM
tw 200 rear rack
tw200 front panniers
tw200 front rack
tw200 luggage rack
tw200 rack
tw200 racks
tw200 rear rack
yamaha tw200 cargo rack
yamaha tw200 luggage rack
yamaha tw200 luggage rack front and rear
yamaha tw200 rack
yamaha tw200 racks
