Wolfman Expedition Dry Bags on the TW200
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Senior Member Rhodetrip's Avatar
    Aug 2010
    If I told you, I'd have to kill you.
    1,732
    Thanks to Tinman Tim's ingenuity, we now have a great option for mounting soft bags on the TW. These Wolfman Expedition Dry Bags are absolutely water and dust proof due to the welded, roll top construction. I don't see why Tim's racks won't work for other brands of soft bags as well, but you're on your own checking the details.
    Tim's racks arrive via Priority Mail. I think he's competeing with Cycleracks to see who can use the most bubble wrap and packing tape to wrap an unbreakable metal object. After 4 hours of removing it, and 3 knife wounds, I finally got the parts unpacked. I'm going to install these on Mrs. Trip's TW, that has been lowered with a V-Star shock, and has had the seat cut down.
    They are all nicely welded and painted to match the cyclerack. Left and right hoops, crossbar, and 2 knobs.
    You start by hooking the side hoops over the cycleracks side and around 2 crossbars.
    Then it just swings down into position.
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Spotwalla: Hidden Content
    Aug 2010
    1,732
    Once both sides are in place, you fit the crossbar between them, under the rack and over the rear fender:
    (I'm attempting to do it backwards in this photo. The tube goes inside the hoop, with the flange facing backwards.) Once its in place, just tighten down on the knobs until its snug.
    This is what it should look like. Total time to install is about 2 minutes.
    Aug 2010
    1,732
    When you order your Wolfman bags, be sure to specify that they are for "Other Racks". Tinman Tims racks will work with several different styles of saddle bags that Wolfman makes. These are the "Expedition Dry Bags"
    The smaller ziplock bags has 8 "D" rings with a doublesided velcro strap on each one.
    What you do is wrap the strap around the vertical hoop and through itself until its all wrapped and snug
    They go on easy, and the velcro sticks to itself
    Aug 2010
    1,732
    Do all 4 corners on both hoops:
    They tell you to stuff a sleeping bag or quilt into each of the panniers to give it the right shape. Inside each is a plastic stiffener to give it shape, and this needs to be removed and fit in properly. Then I stuffed it.
    There are 4 metal buckles on the back of the saddlebags. You loosen the straps,and fit these buckles through the "D" rings, then pull them snug.
    Once all 4 buckles are through, you snug down on the straps and the saddlebags are secure!
    Once both sides are mounted, tighten down on the straps that connect them and run over the seat and rack...and you're good to go!
    For more information on mounting the bags, check out the wolfman video:
    Wolfman bags
    For more information on Tinman Tim's racks and aluminum panniers, as well as photos of my Wolfman Teton bags on my TW, refer to this thread:
    Aluminum panniers
    Senior Member r80rt's Avatar
    Sep 2011
    2,430
    Pretty nice set up, looks like it will work great.
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,344
    Looks Great !! I hear the low rider them song in the back ground. But it sure looks cool.
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
    Ephrata, WA
    1,125
    Looks great. Thanks for the write up.
    1990 TW200
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    502
    Couldn't ask for a better write-up! Thanks Rhodetrip. TIM
    SeatConcepts,carb mod,Shinko tires,15/50 o-ring chain,custom racks f/r, aluminum luggage,windshield,handguards,heated grips,Clarke tank,high frt fender,led running lights,folding shifter, wide pegs,12v outlets,headlight kill switch,voltmeter,stainless header,2nd brakelight,GPS/phone mount
    Senior Member stephenmarklay's Avatar
    Mar 2012
    Spokane, WA USA
    493
    What is the ideal size for the rack with these bags? I have some soft cortech bags I would like to use but they don't have the mounting like the wolfmans. I could try mine but then plan B is to swing for the wolfmans. So getting the perfect fit hangers for the wolfmans is the smart thing to do.
    2011 TW200: Protaper Fat Bars, IMS Pegs, Cyclerack, Moose Racing Tail Bag, Cyrca Handguards, VStrom Mirrors, Jimbo Shield, Oxford Heated Grips, ProCycle 15k spring, 2x2cycles rack, seat concepts, Cyclops Adventure Sports LED conversion
    2014 BMW F800GS
    2007 BMW R1200R
    Sep 2011
    Southcoast MAsshole
    2,584
    looking good!!!
  1. Wolfman "Peak" tailbag on tw200
    By surly357 in forum Performance and Customization
    Last Post: 02-10-2013, 12:32 AM
  2. Saddle bags
    By peter in forum General Discussion
    Last Post: 08-28-2012, 08:52 PM
  3. Where to buy saddle bags
    By josh lam in forum General Discussion
    Last Post: 06-07-2012, 05:38 AM
  4. Tank Bags
    By mtngirl in forum General Discussion
    Last Post: 08-19-2011, 02:18 PM
  5. Moose Racing Expedition Saddlebags
    By dhoenisch in forum General Discussion
    Last Post: 05-23-2011, 12:41 PM
best tw200 bags
dr650 moose expedition saddlebags
make your own tw 200 luggage rack
tin man tim racks
tinman tim racks
tw 200 saddle bags
tw200 racks
tw200 side racks
wolfman advrider
wolfman drybag tw200
wolfman luggage tw 200 motorcycle
wolfman rack for tw200
