Anyone else use an audiable turn signal reminder? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree8Likes
Thread: Anyone else use an audiable turn signal reminder?
  1. #11
    Senior Member Bucknutz's Avatar
    Apr 2012
    Lower Hudson River Valley of The Communist State of N.Y.
    483
    I'll be interested in hearing more on this. Brain dead after a turn is pretty common for me and a few miles down the road I finally notice.
    Tell me about it!
  2. #12
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    5,896
    Quote Originally Posted by Bucknutz View Post
    Tell me about it!
    Ha Ha, You probably would not be busting my chops if you could pass me and not have to see the blink, blink all the time!
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
  3. #13
    Senior Member the-wild-man's Avatar
    Sep 2010
    Columbia County, PA
    194
    UPDATE:
    I finally did try attaching the negative side of the automotive buzzer directly to the brake circuit, but it did not work. The buzzer stayed on even when the brake switches WERE activated. I think it may be due to one of the systems switching the ground side of the circuit, instead of the hot side. But I have not looked at a wiring diagram yet, to see exactly what the deal is.
    Note: Apparently I was WRONG to assume that the "X" terminal of the TRIDON brand flasher unit [needed for LED turn sigs] is the "switched" terminal, with the "L" terminal being the "line" lerminal (I guess the L stands for "load"). For it to work, it needs to be hooked up the OPPOSITE way..
  5. #14
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,395
    Have wired up a turn signal buzzer to all of my rigs. As a DIYer still make them myself with parts from Radio Shack or Amazon. It's pretty straight forward, a buzzer and bridge rectifier. Neither needs to be real special, just 'comfortable' with 12 volts and a couple of amps. Here is the wire diagram recently used on my Honda PCX scooter. Should work for the TW as well, least it did for me. Used the front signals as connections/splice points to the rectifier. The signal input to the rectifier has no polarity, can use right or left on either rectifier lead. The turn signal wire selected does need to be the input/hot, not the ground. One connection to the right signal the other to the left, then you're set.
    littletommy likes this.
    Take care my Friend.........
  6. #15
    Senior Member BillMichaels's Avatar
    SF Bay Area
    240
    I took the easy road a couple years ago. I installed a LED 15 deg. green light in the dash. Really bright when it's flashing. Works for me.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
  7. #16
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    701
    I installed an old automotive buzzer which worked great till it got wet a few times to many so I replaced it with a bright LED dome light bulb. More than bright enough during the day and the odd time I ride at night it totally lights me up making me more visible.027.JPG028.JPG
  8. #17
    Hopefully Out Riding Somewhere In The Sierras
    12,238
    Gerry's buzzer on the MrGizmo bike he sold me has helped me live down the nick-name of "Blinky". The buzzer really helps.
    Tweaker and littletommy like this.
    Lights, Action, Traction....Let's Ride!
    2003 model year, jetted for mile high+ riding, Wiseco 68mm piston, Duro ATV rear tire, IRC GP-1 Trials front tire, XT-225 tank, Cyclerack, 2" handlebar risers, foot pegs, D-flex hand guards, right angle fuel filter, Seat Concepts kit over additional hi-density foam, fluorescent paint, Betty Boop stickers..and a lot of scratches!.
  9. #18
    Spokane, Washington
    13,796
    Fred just now learned what it was because of this thread. Before today, he thought it was Marisa's signal to call him for lunch. No wonder he couldn't get more than a block or two away from the house!!! The first turn and he'd think it was lunchtime and head back home!!
    ***He's going to git me for this one!!
    Cornelis and Tweaker like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
  10. #19
    Senior Member Ukdave's Avatar
    Sep 2016
    Lancashire UK
    108
    I had one on my Z750,
    It was all ready fitted when i bought the bike. The Bright LED was fine but the audible alarm drove me nuts.
    If sitting at traffic lights with turn signal on for more than 30 seconds the alarm would sound, it was very loud and attract unwanted attention from other drivers who thought i was beeping them with my horn. I would switch the turn signal off then back on only for it to start beeping again before the light changed to green.
    1999 TW200E Hidden Content
    2015 R1200GS Hidden Content
    Gone but not forgotten
    2003 XT600e, 1981 XS650, 2000 Z750s, 1990 XV1100SE, RD50, MZ125
  1. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  2. Turn Signal Wiring
    By Jtrez in forum Technical Help
    Last Post: 12-21-2012, 04:01 PM
  3. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
  4. WTB: OEM Turn Signal Indicators
    By joet3ch in forum TW200 Classifieds
    Last Post: 11-09-2011, 01:43 PM
  5. WTB - Turn signal lens.
    Last Post: 11-04-2011, 08:30 AM
