Anyone else use an audiable turn signal reminder?
Results 1 to 10 of 19
Like Tree8Likes
Thread: Anyone else use an audiable turn signal reminder?
    Senior Member the-wild-man's Avatar
    Sep 2010
    Columbia County, PA
    194
    Sometimes (quite often, actually) I forget to turn off my turn signal after making a turn, so I have installed a buzzer device that I pulled out from under the dash of an older junked vehicle. I really helps my peace-of-mind, knowing that I am no longer sending out "false"signals to drivers, which might cause them to turn or pull out in front of me. I was just wondering if there are any other TW200 riders out there who engage in a similar practice.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    It's something I've been going to do as I sometimes forget to cancel the signals, also. My brother found a neat circuit that allows you to silence the beeper at stop lights by pulling the front brake lever.
    socalnative likes this.
    Aug 2011
    Cayce, SC
    3,109
    Now that is cool.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member vegasdesertrat's Avatar
    Nov 2012
    Lost Wages
    100
    I'm looking into doing the same thing, Thx
    Old As Dirt,
    Living in Las Vegas and loving it.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,119
    Quote Originally Posted by B-dub View Post
    Do you have a wiring diagram fir this?
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    6,217
    I'll be interested in hearing more on this. Brain dead after a turn is pretty common for me and a few miles down the road I finally notice.
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
    Jul 2011
    Southwest Utah
    2,132
    The wiring diagram is here.
    Feb 2013
    Missoula, MT
    829
    Sweet! The diagram even has a parts list!
    I'm doing it. Too bad today is labor day. I bet Radio Shack is closed. Maybe not! I'm gonna call.
    rbm
    rbm is offline
    Jan 2011
    4,119
    Thanks!
    Sep 2010
    Columbia County, PA
    194
    The circuit for silencing the buzzer when brakes are applied is a pretty good idea. But depending on how much current the buzzer being used requires for operation, there MAY be a way to hook it up and make it work WITHOUT needing ANY circuitry. What you would do is connect one terminal (the +, if they are marked) of the buzzer to the "X" (switched) terminal of the flasher unit. Then connect the other terminal of the buzzer (-, if polarity is marked) directly to the wire circuit feeding the brake light filament in the taillight assembly.
    The theory of operation would be that the BL filament would act as a low resistance resistor, effectively grounding the "-" terminal of the buzzer, allowing it to operate as long as niether of the brakes are applied. But with either brake applied, the BL filament would be brought up to 12 volts, disabling the buzzer. But this probably will NOT work if you are using an LED TL/BL, as it's resistance when not on likely is too high to allow enough current to flow through it in order to operate the buzzer. But that situation could be compensated for by connecting a reisistor having a low enough resistance, from the brake light circuit, to ground.
    P.S. - I have NOT actually tried this yet. It is as of yet merely an untested theory. I need to get my front wheel situation resolved before I can put any time into confirming that this does actually work. Therefore, I [formally, or whatever] disclaim any responsibility if you fry anything, should you attempt to hook it up in the mannor in which I have described, before I get the opportunity to try it myself.
  1. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  2. Turn Signal Wiring
    By Jtrez in forum Technical Help
    Last Post: 12-21-2012, 04:01 PM
  3. LED turn signal heads up
    By operose in forum Technical Help
    Last Post: 03-24-2012, 09:33 AM
  4. WTB: OEM Turn Signal Indicators
    By joet3ch in forum TW200 Classifieds
    Last Post: 11-09-2011, 01:43 PM
  5. WTB - Turn signal lens.
    Last Post: 11-04-2011, 08:30 AM
