Has anyone added driving lights or fog lights?
Results 1 to 10 of 14
Like Tree1Likes
Thread: Has anyone added driving lights or fog lights?
    Junior Member Handy630's Avatar
    Nov 2013
    Three Rivers MI and Naperville IL
    1
    I just bought a 2008 that had been camo'd up. See pic. I like the look but would like to add round 3" driving lights on either side of the front rack. Any recommendations for lights?
    Senior Member skippyboyo2's Avatar
    Oct 2013
    yorkshire uk
    601
    no picture?
    View my build/off road riding here with lots of pics and vids Hidden Content
    Uk TW/ Suzuki LTZ250 off road rider only
    Flat out or back out.
    Senior Member HappyHiker's Avatar
    Aug 2013
    Lakewood, CO
    323
    Maybe one of the electical gurus can help with the lights - the TW doesn't have a lot of spare electrical power.
    Quote Originally Posted by skippyboyo2 View Post
    no picture?
    The camo job is so well done I cant see it either.
    Senior Member AGman's Avatar
    Nov 2013
    Melbourne, Australia
    617
    Something LED? Try to not to work your charging system too hard.
    Resident Hidden Content specialist. Hidden Content
    Oct 2013
    yorkshire uk
    601
    my mate just fitted an LED light to his ATV and its like daytime when thats on! sure he payed £30 ish from ebay and its waterproof
    Apr 2011
    Martinsville Indiana
    2,052
    Here is what i did Leds and dimmer install
    Or you could run two of the advmonster model 60's and just put a toggle switch to your headlight and turn it off while running the 60's. They are so bright that you wouldnt even if notice your factory was on or off. Not enough juice to run them together
    Senior Member rm_hm's Avatar
    1,619
    Henry J posted this awhile back
    How much can a 2001+ handle? The service manual lists output to be 14 amps at 5000 rpm.
    Lets add up the stock load: Headlamp 60W, Tail 8W, Brake 27W, Flasher 2x 27W, Speedometer 3.4W, Neutral 3.4W High beam indicator 3.4W, Turn 3.4W. That comes to 162.6 watts. Divide by 12 volts and you have 13.55 amps.
    That leaves .45 amps to charge the battery.
    Now I will grant you that I have most everything running. Without the turn signals flashing you might gain a little. When you're not on the brakes you gain a little. As was mentioned, "It is a balancing act." Deduct where you can and you can make additions. From what I see, you better make them small.
    Best case now. Riding the highway with the highbeams on totals 90.8 watts or 7.6 amps. That leaves us room to use almost 6 amps or 72 watts. One 55W light used for cruising might work?
    It all sounds good on paper, but how about the real world? Keep in mind with heat the efficiency declines. So if it is hot the output is less.
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    255
    I mounted these 2" LEDs to my reflector brackets on the forks. They're SUPER bright and built really well. I'm going to buy a pair for my versys as well. You can see them mounted in the last picture
    2" Round 10 Watt LED Mini Auxiliary Work Light | Mini Auxiliary Lights | Super Bright LEDs
    '07 Yamaha TW200 |'08 Kawasaki Versys
    Senior Member HenryJ's Avatar
    Oregon, USA
    179
    Pretty cool to see a quote of mine from so long ago.
    I am still running one halogen projector beam auxiliary light. Works good to light the sides a little better.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Sand Hollow, ID
    9,408
    Quote Originally Posted by mattmus4357 View Post
    From the link provided, one needs to select either a 25 or 45 degree angle. Which angle did you buy?
    @HenryJ, thought of you when I was exploring the Watson/Birch Creek Ranch area's this summer. That and everytime I ride through Ontario. Nice to see you peek in here once in a while.
  1. Running Lights?
    By Mr.Paynter in forum Technical Help
    Last Post: 10-24-2013, 05:53 PM
  2. LED driving lights - update
    By Mozart 2 in forum Performance and Customization
    Last Post: 07-28-2013, 05:03 PM
  3. Custom LED Driving Lights
    Last Post: 07-21-2013, 05:20 AM
  4. Lights Out?
    By arbolmano in forum Technical Help
    Last Post: 03-07-2012, 06:26 PM
  5. Led Lights
    Last Post: 12-06-2011, 04:29 PM
auxiliary lights
yamaha tw fog lights
Tags for this Thread
