1987 electrical question
Results 1 to 10 of 12
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    561
    I have an 1987 TW, It has the original battery.
    It drains every year, I stick the trickle charger on it in spring
    The neutral safety green lamp comes on.
    It kick starts every time, and will kick start all summer long as long as I run it every day or two.
    It never has enough juice to crank with the e-start unless it's right after a nice long ride and the engine is still warm.
    My question is: Would this be possible with 88 and later TW's?
    I'm wondering because Yamaha basically stole the 87 ignition from a kickstart SR185 and kick only XT200/TT225. I checked with the Australian fiche and they still used this 87 style stator setup in the 2005 Kick only AG200.
    Feb 2013
    Missoula, MT
    829
    The original battery??? Impossible. That's 27 years!!! I have trouble (and, I think everyone does) making a motorcycle battery last 2 years.
    If it really is that old: There's your problem. Get a new battery.
    Personally, I don't know anything about the battery and kickstarter vs a 2005 AG200.
    6,024
    It sounds like your basic question is "Can you kick start an '88 and up without a battery in the bike?" Or maybe "a really weak battery in the bike".......I don't know for sure but I am betting you can.
    Senior Member trailscout's Avatar
    Feb 2013
    Yarnell, AZ
    601
    If a lead acid battery is left dead or even a low charge state for an extended time the sulphur plates out as a solid and is no longer available for the chemical reaction that takes place in lead acid batteries. The loss of active sulphur reduces the capacity of the battery drastically.
    I use a DeSulphater on my RV batteries but once they get really bad, the battery is pretty much toast.
    Yep, as others suggested, time for a new battery.
    Ya gotta finish the loop, it's your only way out!
    1987 TW200 OHIO
    561
    Well yes I know it needs a new battery, that goes without out saying....but that wasn't my question
    I only ride this this one from late May to October, and this battery still holds charge enough to kickstart it, I just went and rechecked, the neutral light comes on when the key is turned. Seven days since last charge. I bought this bike in 2001 from original owner and have never done anything to this battery but top it up and trickle charge it.
    My question was, Do other years kick start with zero or low battery power, or is it something with the 87 stator and wiring?
    1987 TW200 OHIO
    561
    Quote Originally Posted by fishguy View Post
    Well the 87 is different from all other year TWs in this area, The AG kick start model is different from the AG E-start in the generator. Yamaha is still using the 87 TW style generator in it's latest incarnations of kick start only agricultural bikes for developing nations.
    1987 TW200 OHIO
    561
    So then the answer to the question is that a 2014 will definitely start and run and the lights will come on if a kick starter is added and the battery is completely dead? The new CDI's don't need external power to create a spark at the plug? Has anyone BTDT?
    Senior Member 66roadkill66's Avatar
    Oct 2013
    roseburg oregon
    312
    ok here is the deal, I have a 87 tw also, has a brand new battery in it and it will go dead in 4-5 days with the key off,and will kick start with a dead battery, I put a switch between the battery and the ignition switch and turn it off when I am not running the bike and my battery will hold it's charge, my guess is the rectifier is leaking voltage and draining the battery. I have been running it this way for the last 1000 miles with no problems so far. My battery will stay up then and I can use the electric start all the time with out having to charge the battery.
    87tw,08 klr650,00dr200,76tl250,73cl175 scrambler,75tl250,76tl125,1960 cushman trailster,
    1987 TW200 OHIO
    561
    That's interesting to know, but why not just replace rectifier, wouldn't that be easier than splicing a switch? I don't mind kicking at all, I figure if it doesn't start cold in two or three kicks then there is something that needs attention.
    On edit, that KE 100 you have, is that a rotary valve version?
    Feb 2013
    Missoula, MT
    829
    Coincidentally, I went to start my '95 TW yesterday. Dead. No lights, no starter, no indicator lights either. Kick started it to run to the Post Office. Got back home okay. Removed seat to charge battery and found the battery totally disconnected. Bolt and nut vibrated loose. Therefore: bike started and ran fine without battery. Lights and turn signals? Not so good. The '87 models and AG's could be different. However, I bet they run without batteries, also.
  1. Dumb question -- bullet electrical connector
    By Deldog in forum Technical Help
    Last Post: 05-26-2013, 12:11 PM
  2. Electrical Question/problem
    By kgriff in forum Technical Help
    Last Post: 09-06-2012, 04:50 PM
  3. Another 1987 Ca tank question
    By vn_grnt in forum Technical Help
    Last Post: 04-21-2012, 10:17 PM
  4. Electrical Trouble 1987
    By Hotrodjohn in forum Technical Help
    Last Post: 07-25-2011, 05:47 AM
  5. 1987 TW200 Ignition/Electrical Problem?
    By snowrider in forum Technical Help
    Last Post: 05-31-2011, 05:58 AM
battery yamaha ag 200 1987
can you start a tw200 on neutral
neutral safety switch
yamaha 1987 200 ag kickstarter
yamaha ag 200 only kickstart year model
