Clutch Slip While Warming Up
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By BRug14468
Thread: Clutch Slip While Warming Up
    Senior Member BRug14468's Avatar
    Aug 2014
    Hilton NY
    213
    Now I know this has been discussed in the past and I have been reading up as much as I can. My issue is with the clutch slipping in the first 10-15 minutes of riding. I usually let my bike warm up for 10 minutes or so before I take off, its been in the 20's or 30's here in Upstate NY. Now after a little bit the clutch bites and grabs and rides fine. I put Mobil Racing 4t 10w40 before the real cold stuff got here. I'm not sure if the washer shim for the clutch springs would be worth my time, not that it could really hurt. In my bikes defense I do tend to ride it pretty hard. Its way more fun to ride a slow bike fast than a fast bike slow. Thanks for any input gentlemen.
    elime likes this.
    5,781
    Quote Originally Posted by BRug14468 View Post
    I can't help with your problem but I do agree with your philosophy.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,477
    Have you checked the return spring on the shifter side of the case. ....where the clutch cable is , most come out of the factory not set properly . There is a thread somewhere on this.
    Also , there is another thread / post / sticky regarding a clutch adjustment procedure , which entails removing the right side (rear brake pedal side ) engine cover.....like you'd do to replace clutch plates.....if this makes since . This is also explained in the Factory service manual .
    Senior Member docjekyll2002's Avatar
    Aug 2013
    632
    My clutch slips too for the first minutes of riding in 5th gear after warming the bike up. It's a little annoying but i think it gives my TW some character
    Senior Member rurlndum's Avatar
    Jun 2013
    446
    Clutch lever free play is less in cold temperatures because the inner cable contracts and won't let the clutch fully engage. I would check this first.
    Senior Member skippyboyo2's Avatar
    Oct 2013
    yorkshire uk
    601
    I've never heard of This issue? It has to be oil realated I'd say, it almost as of the oil needs to hit a certain temp to allow the clutch to grip? Sorry I can't help more!
    View my build/off road riding here with lots of pics and vids Hidden Content
    Uk TW/ Suzuki LTZ250 off road rider only
    Flat out or back out.
  1. Slip on air filter
    Last Post: 05-05-2014, 01:37 PM
  2. Will the clutch slip when the TW gets too warm?
    By Pass Man in forum Technical Help
    Last Post: 03-29-2014, 08:31 PM
  3. Cabin Fever Breakout - Where's Global Warming When You Need It!
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 01-15-2014, 04:13 PM
  4. USED Virago Cobra Slip Ons
    By BuddyMc in forum TW200 Classifieds
    Last Post: 09-03-2012, 07:14 PM
  5. DG slip on?!
    By 530-TW in forum Performance and Customization
    Last Post: 06-03-2011, 07:11 PM
