HELP== new top end, now has loss of power, but has still has high compression???
Results 1 to 4 of 4
Like Tree3Likes
  • 2 Post By littletommy
  • 1 Post By littletommy
Thread: HELP== new top end, now has loss of power, but has still has high compression???
    Junior Member Jassenk's Avatar
    Apr 2013
    10
    I had a base gasket leaking oil . So i checked the compression before i installed the new top end gasket set it was 180 with full throttle..i put a new base gasket, new head gasket, all new seals still has 180 psi but big time loss of power . Any ideas thanks....
    Spokane, Washington
    14,492
    Quote Originally Posted by Jassenk View Post
    Valve adjustment? Timing chain?
    jeffrolives and jbfla like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    Apr 2013
    10
    timing is dead on and if i have the exhaust valve to tight would that cause this
    Spokane, Washington
    14,492
    You want to make sure they are right. It's a little engine doing a hard job and needs to breath. They are adjusted cold. I'm sure you know that, just thought I'd mention it though. Lack of power is typically, air filter, valves, carb and spark plug gap. Of course there are other things, but usually it is within the tune up components.
    Dryden-Tdub likes this.
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    John 3:16-17
  1. Virago 535 Power Loss while driving
    By bluefox in forum Other Bikes
    Last Post: 04-14-2014, 09:47 AM
  2. Virago 535 Power Loss while driving
    By bluefox in forum Off-Topic
  3. loss of power after replacing chain & sprockets?
    By decade03 in forum Technical Help
    Last Post: 03-15-2013, 04:23 PM
  4. Loss of power
    By RTCarroll84 in forum Technical Help
    Last Post: 05-11-2011, 07:06 AM
  5. Loss of top end power
    By DesertMonkey in forum Technical Help
    Last Post: 03-30-2011, 02:07 PM
