Running issues.
Results 1 to 7 of 7
Like Tree6Likes
  • 2 Post By littletommy
  • 4 Post By Purple
Thread: Running issues.
    Member cmercon's Avatar
    Feb 2013
    Vermont
    72
    Running issues.
    So I have a 1987 TW 200. Brand new CDI, New Air Filter, completely rebuilt and cleaned carb (brand new parts used, properly adjusted valves. Starts real easy and idles problem is when you give it gas it dies, this is unless you choke it about 3/4 then it'll idle up then drive it to the mailbox then push the choke in and ride it all day long. But even if its warmed up you have to go through this procedure. This is not a huge issue for me as I can ride it within a min. But my wife can't seem to figure it out. This issue has been eluding me for about a year.
    I don't have this issue with my other 87 or my 14 or my buddies 95.
    What does this sound like?
    Thanks,
    Spokane, Washington
    14,137
    Try adjusting your air/fuel mixture screw out a little more, if that doesn't fix it, perhaps a larger pilot jet (but probably not). Or...just a tad more warm up time. Meanwhile, a strong dose of Seafoam.
    VintageGW and fishguy like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    Mar 2015
    Ynys Môn
    2,330
    My TW takes a couple (or three, even five) mins to warm up - it's normal
    The only way out of that is to take the idle mix screw out to 2 and a half turns as mentioned above - they're well known for it
    "If" your idle screw is already out that far - a dose of sea-foam should help - all good advice from Littletommy .......
    If that lot doesn't work - get back to us and I'm sure we can come up with a few other things to try - but doing those simple first checks will often eliminate the problem, and cost you very little in the process .....
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
    Senior Member VintageGW's Avatar
    Aug 2013
    Fort Worth, TX
    187
    +1 What they said...
    VintageGW's
    4 GL1000 Some of these are for sale....
    1 GL1800
    Gone to a good home - '04 TW200 - Mulita!
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,069
    +1 on the strong dose of Seafoam!
    Feb 2013
    Missoula, MT
    819
    I am lucky. My '95 fires right up and runs flat out. However, I am sure that 2 and 1/2 turns out on the pilot is the reason. It is a bit rich for my taste ((the plug fowls sometimes after sitting for a while (moisture buildup)), but I can live with that.
    Also. I find that valve clearance and timing must be "Spot On" to totally eliminate back fires.
    Remember: on a TW the only computer is between your ears.
    Nov 2010
    2,071
    When the engine is warm try spraying WD40 or some light oil all over the carb. I you get a temporary improvement, the pivot points of the carb are worn out. these would be where the throttle pivots or any othe shaft that goes through from the outside to the inside. Choke, throttle etc. If so the easy fix is a new carb.
    What the oil does is temporarily seal up air sucking in through these worn points. This air leans out the carb too much.
    Phelonius
  1. 93 TW Starting and Running Issues
    By Squatch Buster in forum General Discussion
    Last Post: 08-05-2015, 08:31 AM
  2. charging issues
    By crankyankee in forum Technical Help
    Last Post: 06-16-2015, 07:49 PM
  3. Clutch issues..
    By oldmercman in forum Technical Help
    Last Post: 03-31-2015, 03:34 PM
  4. TW carb issues
    By crossent in forum Technical Help
    Last Post: 07-25-2013, 08:35 AM
  5. 87 CDI Issues
    By keithert in forum Technical Help
    Last Post: 01-19-2013, 06:35 PM
