Engine stalls, terrible noise from the inside - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
Like Tree46Likes
Thread: Engine stalls, terrible noise from the inside
  1. #21
    Nov 2010
    2,210
    If it is oil starvation, you may find damaged rings, cylinders, valve stems & guides, rockers, bearings of rockers, cam, cam bearings, and that is just the upper end.
    If the oil starvation is bad enough it could be crank bearings, con rod & con rod bearings to include wrist pin and piston.
    You might be advised to find a used replacement engine to use while you do a complete rebuild of your original.
    Form what you say, the engine is not safe to ride at all. Find a friend with a trailer.
    admiral likes this.
    Phelonius
  2. #22
    Sand Hollow, ID
    9,667
    Quote Originally Posted by kltrkmpf View Post
    omg ... can't be rescued with just replacing the piston? what else were damaged?
    The cylinder is also scarred but not bad considering how bad the piston is. The cylinder can probably be honed out and is reusable with a new piston.
  3. #23
    6,019
    I haven't seen the cylinder but I bet a lot of what looks bad is aluminum transferred to the steel cylinder lining and that can be cleaned up and you might have a usable though less than ideal cylinder. Honing or boring to the next oversize will definitely save the cylinder.
    I have used many cylinders that others said wouldn't work but they worked fine.
    admiral likes this.
  5. #24
    Member kltrkmpf's Avatar
    Dec 2014
    Singapore
    42
    Could you maybe pay some kids a few Singapore Dollars to help push you broken babe to your place of work? It is something I would have done for free just for the adventure as kid. "Cool, guess what?! I got to push a motorcycle today!"
    Once there if you have the tools might as well remove the cylinder head. Perhaps carefully bag and label all the nuts and bolts if you think another mechanic might finish the job eventually.
    get the kids to help, yes thats one tip i'll note down for future!
    i just managed to reach my work place, luckily in between the pouring rain as its raining season down here in Singapore, took me about an hour & half for 5km, with some pretty steep slope.
    striped the bike, would label the bolt and nuts as advice! thanks so much Fred for all the helpful tips!
    littletommy likes this.
  6. #25
    Dec 2014
    Singapore
    42
    Quote Originally Posted by phelonius View Post
    thanks phelonius! its complicated here in singapore, the law is very strict im not sure how possible it is to use a replacement engine ... trying to open up the engine now to see how bad it is ...
  7. #26
    Dec 2014
    Singapore
    42
    thank you elime! would definitely need your help down the road to recommend replacement piston heads!
  8. #27
    Senior Member kj7687's Avatar
    2,143
    Oh, guess I didn't realize you had ridden 400 km after changing the filter...right then. If it is an issue with the filter, it would be some other issue than "that one".
    KJ, just KJ, ok.
    Current rides:
    2015 Yamaha XT 250, 1997 Suzuki DR 200; 1999 Toyota 4Runner
    Past rides: 2007 Honda Ruckus, 2007 Yamaha TW 200, 2007 Kawasaki Ninja 500, 2009 Kawasaki KLX 331S; 1994 GMC Sierra 1500, 1987 Nissan Pathfinder, 1992 Acura Integra, 1986 Honda CRX, 1989 Jeep Cherokee, 1994 Chevrolet Astro Van, 1979 Volkswagen Rabbit, 1984 Jeep Cherokee
  9. #28
    Dec 2014
    Singapore
    42
    Quote Originally Posted by kj7687 View Post
    Though it is just as bad ... I just opened up my oil filter, it's the correct one with 4 holes, but the oil filter compartment is filled with gooey metal chips.
  10. #29
    Dec 2014
    Singapore
    42
    haven't got the chance to pull the top and cylinder, but a very kind friend had brought his tool set so i can continue.
    though here's what i managed to open up yesterday:
    1/ Valve cover exhaust end (does this look like the valve is intact?)
    2/ Valve cover carb end (does this look like the valve is intact?)
    3/ Timing chain cover
    4/ Oil filter
    5/ Thick gooey metal chipped oil
    6/ Oil filter (correct one with 4 holes
  11. #30
    12,796
    Good photos. Valve stem, keepers,spring, rocker, cam chain, chain tensioner,cam gear all look good.
    Amount of metal shaving at the oil filter does not look good.
    I believe things will not look pretty when you remove the cylinder head. Post more photos of what you find.
    But all is not lost. Now with tools we can lead through next steps. The videos and the thread r.e. base gasket repair should show the next disassembly steps.
    littletommy and kltrkmpf like this.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  1. I feel absolutely terrible...
    By littletommy in forum Off-Topic
    Last Post: 04-28-2016, 01:42 AM
  2. TW200 Starts then Stalls
    By Oleschool in forum Technical Help
    Last Post: 08-16-2015, 03:29 PM
  3. Loud ticking noise from engine
    By Rickr in forum Technical Help
    Last Post: 08-08-2015, 12:05 PM
  4. BW200N 1985 - Rattling Noise from Engine
    By supertarmac in forum Off-Topic
    Last Post: 01-14-2014, 02:56 PM
  5. engine, tranny, or chain noise
    By gussy78 in forum Technical Help
    Last Post: 04-29-2013, 11:48 PM
