Engine stops running when choke is pushed in.
Results 1 to 9 of 9
Like Tree17Likes
  • 3 Post By wrench-puller
  • 1 Post By JerseyJeeper
  • 3 Post By littletommy
  • 1 Post By scotti158
  • 3 Post By jbfla
  • 2 Post By pred
  • 1 Post By SHAG
  • 2 Post By littletommy
Thread: Engine stops running when choke is pushed in.
    Junior Member PJinNJ's Avatar
    Dec 2015
    Central New Jersey
    Question Engine stops running when choke is pushed in.
    Hey guys, longtime biker and rider here with a TW200 I purchased new in March of this year. During the following three months I stored the bike indoors and today finally found the time to get it out doors and see how it rides.
    So, I unlocked it, placed it in Neutral, turned on the fuel, pulled out the choke and pressed the start button. It started up after about ten seconds of cranking and sounded good. As it heated up it was picking up RPMs but showed nothing on the Tach. when it was plenty hot (it was 94 degrees today) the exhaust pipe stopped smoking (the black paint was burning in). This was the first time it was started since a very brief start at the dealers (10 seconds just to show it could start). all seemed perfect until i pushed in the choke. It was just like when I turn the key off. Could the carb on a new bike prepped by a dealer get fouled by sitting for 2 and a half months? or should I look for an electrical issue. No start (cranks when choke is in but not so much as a sputter), starts quickly with the choke all the way out. Nothing as soon as I move the choke in even a fraction of an inch. Any help and or directions would be greatly appreciated. FWIW, my dealer has a dubious reputation for poor work/quality in the parts and service area.
    Senior Member wrench-puller's Avatar
    Port McNeill, B.C.
    535
    There is a little knob for fast idle on the side of the carb below the choke knob, thread that in a few turns and see if raising the idle helps at all as it could be that it is set too low. Failing that, I would return it to the dealer or at least to another Yamaha dealer close by if you don't trust your purchasing dealer and have them check out the carb for you. There is nothing electrical on the choke that would shut off the engine, just that when you come off the primer circuit (choke) the idle circuit must be plugged or out of adjustment. Best let a dealer clean / reset this if it is still under warranty as you can void the warranty if you were to cause any damage to the engine due to carb settings. Best of luck and hope its just the low idle setting!
    Darth, Fred and littletommy like this.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,271
    Where are you in NJ PJ?
    Quote Originally Posted by PJinNJ View Post
    littletommy likes this.
    Spokane, Washington
    14,497
    I think it had ethanol gas in it and with it sitting there, you now have to clean the carb, especially the pilot jet.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    May 2013
    Groton, NY
    2,092
    My thoughts also.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,221
    Pilot jet could easily be clogged in 3 months of sitting, ethanol or not.
    Doubt the dealer will clean it for free.
    At some point, the cap over the pilot screw needs to be removed, and the pilot screw adjusted.
    jb
    2017 Triumph Bonneville T-120.......2015 CSC Zong
    Senior Member pred's Avatar
    Mar 2016
    Philadelphia and Pittsburgh pa
    518
    Just to note,
    On the side of the carb there is a Phillips head screw near the bottom of the bowl,
    If the bike will sit for a week, You can loosen the screw and drain the bowl in 10 seconds and avoid these troubles,
    I never used to drain bowls when gas was petroleum,
    Now I drain anything that will sit for a week, Including allowing the mower to run dry after every use.
    Corn just aint petroleum,
    Peter B
    jbfla and littletommy like this.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    633
    I usually don't warm my bike up. Start with full choke in neutral with clutch pulled in. Head out in about 10 seconds. Push choke in halfway about 200 yards down the road and then after another couple hundred more yards push choke all the way in. This all done at speed with full or 3/4 throttle. Put fresh gas in and try this. If after a few miles when you stop, the engine bogs or quits when you give it throttle, the carb needs to come off to unplug the pilot jet
    05-BMW1200GS- Rock Red 102k miles
    2013-TW200 - 5k- miles
    Spokane, Washington
    14,497
    Use a strong dose of this before tearing into the carb or taking it to the dealer. Use 3 or 4 ounces in a tank of fresh gas.
    fishguy and jbfla like this.
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    John 3:16-17
  1. Replies: 48
    Last Post: 06-28-2016, 08:44 PM
  2. Oil being pushed out the crank case
    By okarmygrunt in forum Technical Help
    Last Post: 04-15-2012, 08:21 PM
  3. rought idle, dies on stops, video inside
    By mexicalimexico in forum Technical Help
    Last Post: 03-19-2012, 04:46 PM
  4. Engine dies when choke is closed
    By jksduke in forum Technical Help
    Last Post: 05-21-2011, 12:59 PM
tk carburettor co ltd labeled
