Fuel pouring out of airbox + running lean - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Like Tree15Likes
Thread: Fuel pouring out of airbox + running lean
  1. #11
    Junior Member travelrider73's Avatar
    Mar 2014
    Palmetto, FL
    19
    I found this piece of advice on a forum for a different motorcycle while using Google. Is this a possibility with the TW200?
    "What is happening is the primary jet is clogged with crap and the system is trying to sook the fuel up through the main jet. This is causing the airbox to fill with fuel"
    I doubt this is the issue since the fuel leaks even when turned off, but I thought I'd add this to be sure.
    Family Toys...
    -2007 Yamaha TW200
    -2007 Yamaha FJR1300
    -2005 Honda Goldwing GL1800
    -2004 Yamaha FJR1300
    -2004 Suzuki SV650
    -1982 Honda CBX
    -and a couple of ATVs
  2. #12
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,271
    I don't think that applies.
    On the top of the needle valve is a little pin, the one you hooked on the float. That's supposed to be spring loaded. Is yours spring loaded and does it operate smoothly?
    With the float attached to the carb and with the bowl off turn the carb upside down so the valve closes. When it's in this position when you blow air in a hose attached to the fuel inlet on the carb is the valve sealed or leaking air when blowing hard?
    dies the needle assembly move smoothly in the seat or dies it bind.
    there really is not much that can cause this.
    XT225 - 1999 Serow... (Now in the Coral!) Yay
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
    Husqvarna 701 - 2017
  3. #13
    Mar 2014
    Palmetto, FL
    19
    Quote Originally Posted by JerseyJeeper View Post
    Yes, and yes.
    Define hard. It's definitely leaking air at about 60psi with the air compressor. If that's a problem, then what's happening? This seems like a simple part.
    Does not bind.
    Family Toys...
    -2007 Yamaha TW200
    -2004 Suzuki SV650
    -1982 Honda CBX
  5. #14
    Mar 2014
    Palmetto, FL
    19
    Update. I took a close look at the old needle vs the new needle and they are just ever so slightly different, so I put the old needle in the new needle assembly and it seems to (maybe) not be leaking. I swear I still feel a touch of air at 60psi, but again, I'm not sure what you meant by "blowing hard". Thoughts?
    Family Toys...
    -2007 Yamaha TW200
    -2004 Suzuki SV650
    -1982 Honda CBX
  6. #15
    Mar 2011
    2,271
    60 lb., I meant blow with your mouth on the hose.
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
  7. #16
    Mar 2011
    2,271
    Set float level per the manual
    Fred likes this.
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
  8. #17
    Mar 2014
    Palmetto, FL
    19
    OK, so just in case that's what you meant, I did try that too... All new parts, it was leaking a little. New seat with old needle, no leak.
    So, even if that means this may be fixed, I possibly have a new problem.
    The rubber plug fell out (the one that's in the other hole that's near the main and pilot jets) -- I think this is a choke fuel pickup, right? Well, the plug is old and hard and won't stay in now. Is it absolutely necessary? If so, my project is on hold until I go buy a new plug unless you have some miracle rubber restoration idea.
    (Thanks for all your help so far!!!)
    Family Toys...
    -2007 Yamaha TW200
    -2004 Suzuki SV650
    -1982 Honda CBX
  9. #18
    Mar 2014
    Palmetto, FL
    19
    Done (as close as I can with the crappy ruler I'm using).
    Family Toys...
    -2007 Yamaha TW200
    -2004 Suzuki SV650
    -1982 Honda CBX
  10. #19
    Mar 2011
    2,271
    Quote Originally Posted by travelrider73 View Post
    You should be able to buy a big thick o-ring and cut a piece to stick in their. Get a Viton o-ring they are gas resistant/proof. They make them real thick. A diesal shop or hose shop should have one. Heavy equipment uses thick o-rings.
    Smitty Blackstone and Peterb like this.
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
  11. #20
    Mar 2011
    2,271
    I'm not sure if it's necessary actually..? Never had an issue with it staying in.
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
  1. Am I running lean?
    By 2Oceans in forum Technical Help
    Last Post: 08-19-2015, 11:35 AM
  2. Gas pouring out from side
    By kince in forum Technical Help
    Last Post: 05-17-2015, 12:08 AM
  3. Running lean, popping and reading my plug
    By cololevi in forum Technical Help
    Last Post: 10-01-2014, 09:49 PM
  4. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
  5. gas running from airbox
    By Retrofit in forum Technical Help
    Last Post: 05-19-2011, 04:32 PM
