New handlebars vs risers
Results 1 to 10 of 17
Like Tree25Likes
Thread: New handlebars vs risers
    Member Rockit's Avatar
    Jun 2016
    Sacramento
    93
    So it looks like the max u can raise the grips and controls with existing cables is 2 inches. Popular options seem to be the Protaper ATV high handlebar or the Powermadd 2 in riser. Which is better and why?
    jtomelliott49 likes this.
    Senior Member tuna's Avatar
    Aug 2016
    Joshua Tree, Ca.
    319
    Be following as I just got my 2002 TW and do have a set of Rox 2" risers. So 2" is as high as you can go with stock cables?
    Senior Member Rhodetrip's Avatar
    Aug 2010
    visiting repair shops nationwide!
    1,721
    I have Rox risers on mine, but the Powermadd are cheaper. The reason I prefer them is you not only raise the bars 2 inches, you can have them rotated forward which makes for a more comfortable riding position for me both sitting and standing. I'm about 6' 1".
    jtomelliott49 and Rockit like this.
    "Cape Breton is lovely all times of year." - Justin Trudeau
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Spotwalla: Hidden Content
    Feb 2013
    Missoula, MT
    819
    I use the Pro Taper ATV bars. The "raise" is just enough, for me.
    I think the 2" risers make the bars higher but I do not know by how much. Seems like I saw a thread here with the measurements.
    Aug 2010
    1,721
    Quote Originally Posted by tuna View Post
    I think that is about it... maybe you could get a little more with some creative routing of the cables. I think the risers only go to about 2 inches, unless you jump to snowmobile risers.
    Feb 2013
    Missoula, MT
    819
    Found this by searching past postings:
    I'm not sure of the stock measurements... but
    Pro Taper SE 7/8" ATV Handlebars
    Raptor Measurements:
    (Width): 770mm
    (Height): 143mm
    (Rise): 115mm
    (Clamp Area): 161mm
    (Sweep): 87mm
    (Control Area): 206mm
    ATV High Measurements:
    (Width): 813mm
    (Height): 160mm
    (Rise): 104mm
    (Clamp Area): 237mm
    (Sweep): 100mm
    (Control Area): 199mm
    ATV Mid Measurements:
    (Width): 813mm
    (Height): 150mm
    (Rise): 93mm
    (Clamp Area): 237mm
    (Sweep): 76mm
    jtomelliott49 and Ukdave like this.
    Member UncleRandy's Avatar
    Feb 2015
    Alaska
    86
    It is possible to go as much as 3" on the TW using Rox Risers (or similar). However, you will have to re-route the throttle cable from the U-shaped clip under the fuel tank that holds the cables close to the frame. It's a very close fit and may preclude using any type of hand guard later.
    Senior Member Dubster's Avatar
    Nova Scotia Canada
    553
    I have the ProTaper ATV High bars on all my bikes except my V-Strom. They give me the increased height I need plus they are wider than stock which I prefer when offroad.
    I have the Rox Risers on the Strom because I don't need the wider bars for mainly street riding and I like the adjustability enabling me to find the "sweet spot".
    ejfranz, jtomelliott49 and Rockit like this.
    09 DL650 V-Strom "Function over Form at a Superior Price"
    09 DR650 "Hooliganizer"
    03 TW200 "No Road---No Problem"
    02 Tw200 " Camouflaged Redneck Edition"
    73CT Trail90 "The most fun you can have under 100cc's"
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    678
    I have the 2" PowerMadd and an off-brand ATV high-bar handlebar. I used both because I also have a Clarke XT350 tank and the PowerMadd riser allows the bars to be rotated forward, providing clearance off the tank, but the higher handlebars allow the controls to be rolled back towards me again. The cables did need to be re-routed, but they are stock. Essentially, I have a 3" rise, but the pull-back keeps the cables within reason.
    jtomelliott49, ejfranz and Rockit like this.
    My 2-Wheel Babies: 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2011 Genuine Scooter Co Blur 220i - 1996 & 1999 Yamaha TW200
    5,862
    I am using a cheap set of McFly ATV bars from Cycle Gear for < $20. I also took a second set of caps, the things that hold the handle bars on, and flipped them upside down and used them to raise the bars a little bit more. I think I have less than 30 bucks invested and it is about a 1 1/2" to 2" total lift.
  1. Handlebar Risers
    By scotti158 in forum Performance and Customization
    Last Post: 03-30-2014, 12:28 PM
  2. Homemade Risers
    Last Post: 03-23-2014, 10:08 AM
  3. PowerMadd pivoting risers versus Rox pivoting risers
    By old white truck in forum Performance and Customization
    Last Post: 02-12-2014, 09:49 PM
  4. risers
    By sea bass in forum Performance and Customization
    Last Post: 06-23-2012, 01:17 PM
  5. Bar risers
    By tkrrox in forum Technical Help
    Last Post: 08-08-2010, 12:06 AM
