Risers
Results 1 to 10 of 16
Like Tree39Likes
Thread: Risers
    Junior Member revtbob's Avatar
    Jun 2016
    18
    Risers
    This may be an elementary question, but here goes: I am thinking of installing 2" risers on my 2011 TW in order to get maybe a more comfortable position. I haven't ordered any yet, but upon looking at the cable slack and routings, I'm wondering if will work without major cable work.
    Some here have mentioned re-routing the cables. Do you have to disconnect them to do that? And where. Do you re-route them? There doesn't seem to be all that much room.
    littletommy and jtomelliott49 like this.
    Apr 2014
    Dryden NY
    5,336
    Quote Originally Posted by revtbob View Post
    You will be fine with 2" risers. No re-routing required.
    Tom
    Never, in the history of mankind, have lives, less lived, been so well chronicled.
    Hopefully Out Riding Somewhere In The Sierras
    12,238
    2" risers are a common no-hassle popular modification. I would recommend 2" risers for greater comfort and control both seated and when standing on the pegs.
    Lights, Action, Traction....Let's Ride!
    2003 model year, jetted for mile high+ riding, Wiseco 68mm piston, Duro ATV rear tire, IRC GP-1 Trials front tire, XT-225 tank, Cyclerack, 2" handlebar risers, foot pegs, D-flex hand guards, right angle fuel filter, Seat Concepts kit over additional hi-density foam, fluorescent paint, Betty Boop stickers..and a lot of scratches!.
    Senior Member Michael Bryce Winnick's Avatar
    Oct 2015
    608
    http://www.parts-unlimited.com/produ...umber=06020439
    These are the best risers in the world. Made in USA. I chose to reroute my cables to the outside of the handlebars, but it probably is not necessary. Nobody should buy any other risers than these.
    2 inch pivot risers for 7/8 bars. Order them today so you can get them on your bike and ride before it snows. You can do wheelies easier with risers. Real benefit- When you upgrade the appearance and function of your bike with a Clarke tank (which everyone should do), your bars will clear the tank. This is big. I had to replace my risers (1.25 inch up and 1.25 inch back). This is the right p/n also.
    Hailey, ID
    2,399
    Quote Originally Posted by Michael Bryce Winnick View Post
    RISER 2" ROX PIVOT 7/8 N | Products | Parts Unlimited®
    These are the best risers in the world. .....
    +1 ! I've had mine since 2010. For me, being able to move the bars 1 inch forward as well as nearly 2 inches up was the clincher. I never touched the cables, no problem there at all.
    Rocky
    2010 TW200
    2014 BMW R1200GS LC
    Junior Member Yam200's Avatar
    Nov 2016
    23
    any idea if these PowerMadd 45430 PowerRiser 475 - 2" Tall X 4.75" Wide, 7/8" bars to 7/8" bars will fit the TH200 handlebar clamps spacing? Think I'd feel better with a one-piece design. They are $ 55.51 at Amazon. Thanks for comments
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    701
    Its to cold up here for my wife to ride the TW so I put my 2" Rox risers back on. What a difference. Gee I hate sharing my TW.
    Member Eric's Avatar
    Jun 2014
    Helena, MT
    62
    Yam200 - I have that same riser, PowerMadd 475. I bought it from amazon too and have been riding with it nearly a year. It fits just fine and no issues with needing to change cable length or routing. Really helped my hand position (I'm 6'3"). Easy install and no problems since. Enjoy if that's the way you go.
    2013 (old stock bought new by me in 2015), 700 miles as of May 2016, 14/55 with DID o-ring at 50 miles, Cyclops 3800 LED, superbright.com tail/brake LED (1157-R45-T: 1157 Red), superbright.com turn signal indicator (BA9S-G4-32-12VAC: Green 32 Degree 12V), ebay bark busters, ebay wide footpegs, manracks with rotopax, 1 gal rotopax, plasti-dip on all plastics Oct 2015, ebay mirror extenders, 80% trail/20% road, ALL maintenance per manual, BY ME ONLY (more freq. oil changes, reusing orig. filter)
    Nov 2016
    23
    Thanks Eric - a bit late with my reply, sorry. The 475 is in the mail. Can't wait to get it mounted.
    Nov 2016
    23
    mounted the 475 without problems and cables were long enough. Trying to fond the best position: moving the handle bars towards the front or back. Guess is a matter of comfort and control for each individual. Have them straight for now.
  1. Maximum Risers
    By RobG in forum Technical Help
    Last Post: 02-07-2016, 06:32 PM
  2. best bar risers ?
    By 01dually6.0 in forum Performance and Customization
    Last Post: 10-23-2015, 06:25 AM
  3. PowerMadd pivoting risers versus Rox pivoting risers
    By old white truck in forum Performance and Customization
    Last Post: 02-12-2014, 09:49 PM
  4. risers
    By sea bass in forum Performance and Customization
    Last Post: 06-23-2012, 01:17 PM
  5. Bar risers
    By tkrrox in forum Technical Help
    Last Post: 08-08-2010, 12:06 AM
