What can I do to make my tdub start and idle better? - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Like Tree86Likes
Thread: What can I do to make my tdub start and idle better?
  1. #21
    Dec 2015
    San Diego
    829
    A new pipe and jetting is not going to make the bike wheelie just louder. I bought mine cheap with the pipes because the PO had trouble tuning the carbs. I like them but I am not sure I would go out and buy pipes if they didn't have them. If you need a new pipe and like the look and sound then go for it. Be prepared to rejet.
    You can learn wheelies on a TW is it a clutch technique. There is a youtube video on how to do it. Be prepared to dump your bike while learning so maybe not learn in the street.
    If your boots are stiff they should be replaced, that cracked one definitely. Also as elime says about the main jet replace the pilot jet for the same reason.
    littletommy likes this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
  2. #22
    Feb 2013
    Missoula, MT
    801
    Yes. Bummer. On my '95 TW the old boots had also shrunk so that the fittings were mis-aligned. The connection of the carb to the head MUST be air TIGHT.
    Tweaker and littletommy like this.
  3. #23
    5,790
    Cut those rubber tabs off and you will be able to rotate the carburetor without ripping the manifold.
  5. #24
    Senior Member Rokon84's Avatar
    Feb 2016
    Iowa
    103
    Does anyone have the link or info on where to find the $15 carb boots?
  6. #25
    Spokane, Washington
    13,861
    Not sure about cheap boots, but if you need a intake manifold...
    Carburetor Adapter for Yamaha TW200 2JX TW 1987 2000 Joint Carburetor New | eBay
    Tweaker and fishguy like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
  7. #26
    Feb 2016
    Iowa
    103
    A $13 carb kit is prly junk right? Comes with a116 and 38 jet. My current jets are 114 and 40?
  8. #27
    Spokane, Washington
    13,861
    I think you are better off buying original Yamaha parts for the most part.
    Quote Originally Posted by Rokon84 View Post
    Tweaker, ToolmanJohn and Fred like this.
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    John 3:16-17
  9. #28
    Senior Member ToolmanJohn's Avatar
    Nov 2016
    Bristol Connecticut
    102
    BOATS.net for all those small parts if your local Yamaha dealer is too far away.
    The small parts are cheap. Get Yamaha OE parts.
    littletommy, Tweaker, Fred and 1 others like this.
    2013 Yamaha TW200 (Current) - Shinko SR41, Enduro Mirrors, Seat Concepts Foam and Cover, Generic Handguards (GOOFIT) requiring 5+ hours of diddling to install......You've been warned.
    2007 Kawasaki Ninja 650R (sold) Fun for a year, then mega garage DUST collector
    1985 Honda CB650SC Nighthawk (sold) FUN - but became a dust collector
    1984 Honda CB450SC Nighthawk (sold) Primary transportation for almost 5 years
    Various other 2 wheel rolling junk not worthy of mention....
  10. #29
    Feb 2016
    Iowa
    103
    So is the consensus to stick with new 114 & 40 jets if I buy new ones ? Or would some of you recommend a different size? I May be near a Yamaha dealer tomorrow to buy parts. I Also noticed when I installed the pilot screw that the oring was on it but I didn't seem to feel much resistance from the oring, so maybe I should replace it or better yet just put a carb kit in. Maybe that oring has shrunk ?
  11. #30
    5,790
    Personally I would stick with the 114 / 40. On my TW with the 70mm piston I have gone to a 112 jet and noticed a slight improvement -- I tried a 110 but didn't notice any improvement so back to the 112.
    Affirmative on a good o-ring for the pilot screw. I had one with a worn o-ring and it leaked so much air no matter how much I unscrewed it the mixture didn't get any richer. With a new o-ring all was good.
    Try putting the pilot screw in upside down to test how well the o-ring is sealing. If it is real loose it isn't sealing at all.
  1. HIGH idle upon cold start at full choke?
    By mckee1710 in forum Technical Help
    Last Post: 11-26-2015, 12:44 PM
  2. Hard start, Rough idle and Surging. This is what I did.
    By Mr. Magoo in forum Performance and Customization
    Last Post: 08-31-2015, 03:21 PM
  3. A Game Where You Can Make A TDub
    By Jon62602 in forum Off-Topic
    Last Post: 07-16-2015, 10:55 PM
  4. Now and then. Where did your TDub start and what has it become.
    Last Post: 09-25-2013, 07:07 AM
  5. Tdub won't start electrical burning smell!
    By Beewerks in forum Technical Help
    Last Post: 09-03-2013, 02:00 PM
