What can I do to make my tdub start and idle better? - Page 5
Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Like Tree86Likes
Thread: What can I do to make my tdub start and idle better?
  1. #41
    Member wmgeorge's Avatar
    Feb 2017
    Ankeny, IA
    57
    Quote Originally Posted by Rokon84 View Post
    Adjusted valves....set them at max clearance of .004 intake and .006 exhaust. They were slightly tighter than that when I checked them before starting. They were at .003 intake and .005 exhaust. I saw no noticeable difference in starting the bike. Checked the idle screw...it's at 2 turns out. I guess I'll havta take the carb off and have it ultrasonically cleaned.
    I am in Iowa also, where do you buy your gas? I never use ethanol in my small engines, some pumps in Iowa are not marked. In Missouri we had a boat at the lake and I would bring gas down from Iowa. Premium gas from a place that sold a lot, like BP. All gas in Missouri has Ethanol, pumps are not marked in most cases. My guess that is the issue.
    Ethanol is grain alcohol and it attracts or absorbs water very easily . That mixture will corrode jets, and I have seen the damage its done to floats, needle valves and float bowls. Its fine for a couple of weeks then things go bad. They make a StaBil for that stuff but I would think Sea foam would help. Don't know because I don't use ethanol.
    Ken likes this.
    Retired guy Central Iowa, Lots of Hobby's
  2. #42
    Senior Member Rokon84's Avatar
    Feb 2016
    Iowa
    103
    Well my new jets don't have 10 miles on them. And I haven't used anything but premium since I've owned it. I'll try cleaning carb again and installing a kit.
    Ken likes this.
  3. #43
    Feb 2017
    Ankeny, IA
    57
    Are you sure your tank is clean? Coild be something getting in the gas, I would just pull the float bowl off and see what is in there. If there is, drain your tank from the bottom. all even the reserve, and put in a couple clear glass jars, and see what settles out or if has any water in it. Gas that will run in a car or truck might be bad for a motor cycle if it has crud in it. Bad gas is more common than you think.
    Ken likes this.
  1. HIGH idle upon cold start at full choke?
    By mckee1710 in forum Technical Help
    Last Post: 11-26-2015, 12:44 PM
  2. Hard start, Rough idle and Surging. This is what I did.
    By Mr. Magoo in forum Performance and Customization
    Last Post: 08-31-2015, 03:21 PM
  3. A Game Where You Can Make A TDub
    By Jon62602 in forum Off-Topic
    Last Post: 07-16-2015, 10:55 PM
  4. Now and then. Where did your TDub start and what has it become.
    Last Post: 09-25-2013, 07:07 AM
  5. Tdub won't start electrical burning smell!
    By Beewerks in forum Technical Help
    Last Post: 09-03-2013, 02:00 PM
