What can I do to make my tdub start and idle better?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Like Tree87Likes
Thread: What can I do to make my tdub start and idle better?
    Senior Member Rokon84's Avatar
    Feb 2016
    Iowa
    103
    Thanks to this forum I rebuilt the top end of my first tdub last spring. Because I had to...after only a few miles of riding it for the first time the motor locked up because the last person to change the oil didn't use the correct filter. So I say thanks. And hope now you can help me get it idling a bit better.
    I just ordered a new battery and it has me thinking I want this thing to run better than it did last year. I cleaned the carb and messed with the adjustment screws to no end. Still doesn't idle to my likings and takes forever to warm up enough to take the choke off. So I'm wondering what my options are. I can dismantle the carb and soak it. What about shimming the needle? I've read some stuff on that, is it good idea ? I don't want to modify this thing to the extent that it needs new exhaust and intake blah blah blah. But I would like a good idle and as much power as I can reasonably get fairly cheaply/easily. From some stuff I've read would it also be a good idea to move up a size on the idle jet? I'm not sure what it has now. It is a 1997.
    I think I also have clutch issues, it doesn't engage till the lever is almost all the way out. I think I have done all the adjusting i can do without tearing into the clutch, which I've never done. Is it likely I need new clutch discs or is there some kind of internal adjustment as well? Are clutches hard to work on? I have a parts motor with a brand new clutch in it I can practice on or maybe swap parts out of?
    Dec 2015
    San Diego
    916
    I don't have your year carb but if you are adjusting the pilot mixture screw and it isnt doing much. I would check to see that all the parts are there for pilot needle screw, spring and o ring. A bad oring on the screw can cause problems. You might replace the pilot screw assembly. I would replace the pilot jet with a new one in the stock size, maybe buy a larger one for later to try. I would also try and clean the pilot jet area again. Remove the pilot screw and also the pilot jet to do this. Your carb and all the parts have to be good, also clean before trying to tune the carb. May sure you don't have carb boot air leaks. This can cause a lot of idling problems.Spray WD-40 by the boots when the bike is running if it speeds up you have boot air leaks. Under the tech stickies Lizrdbrth has the procedure for adjusting and tuning a carb. Carefully read that. After you get it idling right then you can try shims on the needle to improve acceration. My bike had a hesitation the shims fixed caused by a pipe.
    I haven't messed with my clutch except to remove it to install a kick starter. It's not hard but you need to learn what to do. Plus there is a cover gasket that is a pain to R and R. That being said our clutches seem to let out near the top. Check your spring where the lever comes out of the motor on the left side to see if it is on where it should be.
    Have fun learning this stuff it is rewarding.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Phoenix
    968
    Honestly, before you do something crazy- make sure it isn't the cold that's making it start shitty. The TW is known for not wanting to start as soon as it starts to get even slightly coldish.
    mudbug and admiral like this.
    Senior Member Jut8's Avatar
    Nov 2015
    Beaver, PA
    150
    This probably won't fix everything for you, but I know a few others (myself included) have put an ngk iridium plug on theirs and have had good results, it's a cheap $8 at any auto parts store, it seemed to help my 08 and 13 a touch...enough to the point that I never have touched the carbs on either. Might be worth a shot
    -13 TW200
    -08 DRZ400s
    -08 Roadstar warrior
    -15 Sherco ST 3.0
    -08 Aprilia Tuono
    -Missing my DR650 a little bit
    Senior Member ToolmanJohn's Avatar
    Nov 2016
    Bristol Connecticut
    118
    Quote Originally Posted by Rokon84 View Post
    The short range of clutch engagement is normal for TW 's . It seems like the last 1/2 inch of letting the clutch lever out is where it starts engaging. My 2013 is the same and it had only 881 miles when I bought it. I did an oil change and it still acts the same. Clutch feels the same as well, no big difference that I could tell. I didn't like how far away the stock levers were from the grips, so I bought some adjustable reach levers and that has improved how things feel tremendously. I recommend adjustable levers for everyone. The hand controls are where a lot of safety and control is.
    2013 Yamaha TW200 (Current) - Shinko SR41, Enduro Mirrors, Seat Concepts Foam and Cover, Generic Handguards (GOOFIT) requiring 5+ hours of diddling to install......You've been warned.
    2007 Kawasaki Ninja 650R (sold) Fun for a year, then mega garage DUST collector
    1985 Honda CB650SC Nighthawk (sold) FUN - but became a dust collector
    1984 Honda CB450SC Nighthawk (sold) Primary transportation for almost 5 years
    Various other 2 wheel rolling junk not worthy of mention....
    Jan 2017
    Southern Nevada
    205
    +1 to Tweaker's comments.
    When a mixture screw does not respond, either the pilot is too lean or there are vacuum leaks, if the carb is intact.
    Smitty Blackstone and Ken like this.
    Jan 2017
    Southern Nevada
    205
    Quote Originally Posted by ToolmanJohn View Post
    The short range of clutch engagement is normal for TW 's.
    +1
    True for my 2017 with only 400 miles on the clock in the past month.
    Ken likes this.
    Feb 2016
    Iowa
    103
    I have never heard of an adjustable lever like you speak of...if it's different than a stock lever. I'll have to check into that. With my small hnds I feel like a shorter stroke lever would make me feel more in control esp with my 4 or 5 yr old on back. And the starting issue and idling issue has nothing to do with air temp in my case I don't think... it starts and idles the same way all summer and I don't ride in the iowa winters. I'll take a good look at the carb and try the wd40 trick to check for air leaks. Those carb boots are pricy if I remember right and mine are pretty stiff more than likely 20 years old
    Tweaker likes this.
    Mar 2015
    Ynys Môn
    2,332
    Just makes it easier to do on the fly .....
    littletommy, Tweaker and Ken like this.
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,486
    What's your elevation......above sea level.
    May need to install larger main jet.
    Yes , shim the needle ( all aspects of carb tuning should be in the " sticky""). 2-2.5 turns out on the pilot screw usually does the trick. As advised above, check for vacuum leaks , especially at the carb boots , both of them. Make sure float is at proper "setting" / not sticking.
    Are you running Ethanol fuel ?. Make sure air filter is properly oiled too. Happy riding on one of the best bikes to EVER grace Earth's surface.
  1. HIGH idle upon cold start at full choke?
    By mckee1710 in forum Technical Help
    Last Post: 11-26-2015, 12:44 PM
  2. Hard start, Rough idle and Surging. This is what I did.
    By Mr. Magoo in forum Performance and Customization
    Last Post: 08-31-2015, 03:21 PM
  3. A Game Where You Can Make A TDub
    By Jon62602 in forum Off-Topic
    Last Post: 07-16-2015, 10:55 PM
  4. Now and then. Where did your TDub start and what has it become.
    Last Post: 09-25-2013, 07:07 AM
  5. Tdub won't start electrical burning smell!
    By Beewerks in forum Technical Help
    Last Post: 09-03-2013, 02:00 PM
