My '96 is needing a new battery. Looking at the Shorai Lithium battery (LFX14L2-BS12) Just wondering if anybody here can give some feedback about this battery before I buy it. Thanks everyone!
Looks like that battery hasn't been around long, don't see a lot of feedback online. For the money saved, I just might try it though.How about this one?
NEW WPS Lithium Battery Featherweight Light Yamaha BW200 TW200 HJB7BL-FP-IL | eBay
Tom
The link you provided looks like they are manufactured in the same plant as the WPS branded batteries I posted. I did not see a two year warranty on the ones you posted though? I may have missed it.I have been looking at these batteries. When I get through playing with the cells I bought and if they don't work out I may buy 2 of these to try. Almost all of these lithium motorcycle batteries have lifepo4 cells in them with BMS circuits to protect from over charging and discharging them too far. They most likely have a charge controller in them to keep the charge voltage below 14.4 V. They don't mind sitting partially discharged it doesn't hurt then no sulfating. But float charging them when they are full is not good for them it reduces capacity. Ideally a lithium charger should turn off and then back on after a voltage set point these batteries may have that circuit in them.
https://www.aliexpress.com/item/12V...id=a8962ad4-23d1-45fe-ace1-7579af459935&tpp=1
You can get 2 for @ $100.
I now have the Battery Tender batteries in both TW's and my 1600. Made a "battery box adapter" for the TWE's instead of trying to use the foam blocks that were supplied with the batteries.
