A Battery Question - Page 3
Results 21 to 30 of 34
Like Tree134Likes
Thread: A Battery Question
  1. #21
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    162
    I have the Battery Tender lithium battery and the BT lithium charger - had it for the last 3 months. Very happy thus far. There were several nights that got down into the teens here and the TW always turned over quickly and started right up. A little over 1/3 the size of stock battery, way lighter and said to have a much longer service life.
  2. #22
    Senior Member centralwarider's Avatar
    Mar 2015
    Washington State
    151
    The old lead acid battery was not doing well this spring. Several failure to starts. After charging up, the old battery read 12.8 at its highest. Still not doing well and so I have a good excuse to buy fancy bike stuff.
    Chose the Battery Tender lithium battery. Staff at Battery Tender told me that charging with my Battery Tender Jr (for all batteries) would be fine. Chose the 120 as it was smaller. Cost $84 on Amazon. The 240 specs said it was 5.27" and my battery box sure seems to be 5" wide otherwise I may have gone next size up. Here is a comparison of size. The battery is terribly light.
    The lithium came out of the box reading 13. After charge up here.
    I used a couple of bits of pipe insulation to add to the foam inserts that came with the battery. I used all of this fill material and still the battery feels as if it may move. I'll keep an eye on this.
    2007 TW200, Cycleracks, Jimbo shield, Tinman Tim racks and tool tube mount, Shinko 244 in 5.10, Protaper ATV mid handlebars, Tusk D-flex hand guards, e-bay steel pegs
  3. #23
    Mar 2015
    Washington State
    151
    Final
  5. #24
    May 2013
    Groton, NY
    2,091
    I now have the Battery Tender batteries in both TW's and my 1600. Made a "battery box adapter" for the TW's instead of trying to use the foam blocks that were supplied with the batteries.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  6. #25
    Mar 2015
    Washington State
    151
    Quote Originally Posted by scotti158 View Post
    I now have the Battery Tender batteries in both TW's and my 1600. Made a "battery box adapter" for the TWE's instead of trying to use the foam blocks that were supplied with the batteries.
    Lets see a picture scotti158. Your adapter sounds interesting
  7. #26
    May 2013
    Groton, NY
    2,091
    Quote Originally Posted by centralwarider View Post
    Basically a plywood box glued and painted with the outside dimensions the same as a lead acid battery. I'll pull the seat and get some pics when I get the chance.
    2013 Yamaha TW200
    1996 Yamaha TW200
  8. #27
    May 2013
    Groton, NY
    2,091
    Here it is. Helps to have a basement full of woodworking equipment.
    2013 Yamaha TW200
    1996 Yamaha TW200
  9. #28
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    744
    I liked the idea of using the small metal box and putting tools, patches etc in it then sliding it in the extra battery space. I think it was a gift card box. Someone posted that a while back.
  10. #29
    Dec 2015
    San Diego
    1,064
    Quote Originally Posted by Dryden-Tdub View Post
    The link you provided looks like they are manufactured in the same plant as the WPS branded batteries I posted. I did not see a two year warranty on the ones you posted though? I may have missed it.
    Tom
    They have a one year warranty.
    scotti158 and jtomelliott49 like this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, modified Krator foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
  11. #30
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    281
    I had a wps battery in my daughter's quad but I always worried about it. That wps was a lipo and knowing how unstable they were in rc cars made me nervous. Next time I buy a lithium it's going to a shorai which aren't lipo.
    Sent from my iPhone using Tapatalk Pro
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
  1. Replies: 6
    Last Post: 08-09-2015, 11:22 AM
  2. question about headlight and battery not charging
    By richyboy111 in forum Technical Help
    Last Post: 10-13-2014, 11:17 PM
  3. Dead battery question:
    By drake523 in forum Technical Help
    Last Post: 09-20-2013, 06:59 AM
  4. Battery question
    By kj7687 in forum General Discussion
    Last Post: 01-23-2012, 05:37 PM
  5. Hollow Mod... Battery holder question
    By workinprogress in forum Performance and Customization
    Last Post: 09-28-2010, 07:47 PM
