Should Have Started with a Bigger Pilot Jet
Results 1 to 5 of 5
Like Tree15Likes
  • 10 Post By Welder
  • 3 Post By Tweaker
  • 2 Post By Welder
Thread: Should Have Started with a Bigger Pilot Jet
    Senior Member Welder's Avatar
    May 2015
    PNW
    110
    I have two 2015 TWs. Both ran lean as heck new from the factory... backing firing on decel, needing choke for the first mile of riding even after a long warm up period or else any throttle would kill the engine, surging at light load and throttle, rough running rolling off a closed throttle, and common single massive detonation events in warm weather with a warm engine during cranking to start up. My bikes are all stock with the 2015 Teikei carbs. I am close to sea level.
    I tried adjusting the idle mixture screws which helped, but not near enough. The only problem it completely eliminated was the back firing on decel. I found opening the screws beyond a certain point, about 1.5 turns, had no further effect on idle speed, and they were still too lean. I tried running with the screw out 2-3 turns but it seemed to make little difference after about 1.5 turns out.
    I just put in a 34 pilot jet and the bike ran instantly better. Started right up, ran way better when cold, ran better when warmed up. It was 36 F out and raining / frozen raining. I will do some experimenting with the idle air screw when time allows, but for right now I notice the same thing as with the stock pilot jets.... after turning the screw out a certain amount, about 1 turn now with bigger pilot, it seems to have little effect on idle speed.
    BTW I also <previously> tried shimming the needle and bigger mains as that seems a popular thing to do. Running both bikes side by side in warm weather, the totally stock bike ran crisper in the mid to full throttle range, and out ran the rejetted bike. I pulled the shims and went back to the stock main jet.
    Anyhow I will experiment more with screw adjustments when it isn't late, dark and raining. But for now I can see I was wasting my time with everything else until the bigger pilot jet went in. It appears to me that should be the place to start when trying to make the TW run right.
    Dec 2015
    San Diego
    924
    I only upped the main jets on my bikes because of the aftermarket exhausts called for it. The shims on the needle may improve throttle response depending on the bike. The bigger pilot jet did get rid of cold bloodedness on my bikes.
    Welder, littletommy and grewen like this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
    May 2015
    PNW
    110
    52F and not too wet today. I went with 1 1/8 turn on the 34 pilot (other wise 100% stock) and it starts and runs great! Wish I would have done this 2 years ago.
    I still haven't changed the wife's pilot yet, will do soon. Like mine used to, it CRACKS sometimes on turning over. One big detonation event. I have to think that over time this would bust up the ring lands. Seems crazy the bike is delivered like this.
    littletommy and jtstdub like this.
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    256
    Quote Originally Posted by Tweaker View Post
    So I'm heading to chaparral tomorrow to pick up a few things and thought it would be a good time to grab a couple jets. Since we live somewhat close and similar elevations, what did you settle on for your carb jetting (just pilot and main)? My 2016 still has the stock 126 and 31 and I want to richer it up just a bit. I know you went up on the pilot a bit, but how about the main? My tw still has the stock exhaust.
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    Dec 2015
    San Diego
    924
    Chaparrall may have to order the jets my dealer didn't stock them. Take the numbers with or call them to order then pick up no shipping charge. You could get a #34 pilot to try and a 128 main. I don't know if you need a 130 main jet with a stock exhaust. Also there is #125 jet maybe for high altitude along with the stock #126. I think it might be good to order an extra bowl gasket too.
  1. Replies: 78
    Last Post: 08-08-2016, 05:46 PM
  2. Pilot Jet vs Pilot Screw adjustments
    By Tee Dubbs in forum Technical Help
    Last Post: 05-23-2016, 05:04 PM
  3. pilot jet
    By greendub in forum Technical Help
    Last Post: 08-27-2013, 07:16 PM
  4. Pilot Jet
    By Joe in forum Technical Help
    Last Post: 01-11-2012, 07:34 PM
  5. bigger pilot jet?
    By DDavis in forum Technical Help
    Last Post: 10-25-2011, 01:02 AM
