TW Clutch Renewal Advice Wanted
Results 1 to 6 of 6
Like Tree28Likes
  • 3 Post By rogerww
  • 5 Post By socalnative
  • 7 Post By TW-Brian
  • 9 Post By elime
  • 3 Post By rogerww
  • 1 Post By Ken
Thread: TW Clutch Renewal Advice Wanted
    Junior Member rogerww's Avatar
    Oct 2012
    Blairsville GA
    18
    RE: 2004 TW200, 6k miles. The clutch is a typical crappy one, grabby, or usable friction-zone and then it ‘engages itself,’ albeit slowly, without easing the lever out further. I assume a new clutch or clutch assembly, particularly an improved aftermarket such, would provide a better clutch, and smoother friction-zone modulation.
    What do I need to buy in order to do a clutch job properly? What land mines are lurking inside the cases?
    Thanx!
    jtomelliott49, Lomax and Ken like this.
    Nov 2016
    So. California, inland empire
    265
    From my riding experience, with various mileage TWs, and from some research on the clutch "abruptness" and very short engage/disengage point, I don't think a new or aftermarket clutch will change the grabbiness that much.
    I haven't read anything that indicates a much smoother or better feeling clutch in general happens with new or aftermarket clutch kits.
    But the good new is that internal clutch mechanism is very much like most dirt bikes I've seen.
    Metal and fibre clutch plates, metal clutch basket, springs for tension, throw-out rod in center. There are smaller covers which are a little easier to deal with. You can do it without draining the oil but I always suggest you do it while changing the oil anyways.
    If it's not slipping in 4th or 5th I wouldn't worry about it.
    Make sure the return spring is in the right spot and adjust the cable free-play to get the release point where you want on the lever and just use it.
    Pleasanton, CA
    4,368
    It is not difficult to replace the clutch in a TW. What you will need is a new gasket for right side (clutch side) cover. You might also want to order a new lockwasher for the clutch basket. The original lockwasher has two locking ears, so you may not need the new one, but it is a good idea to have it in case you need remove the clutch for a second time.
    It is not even necessary to drain your oil if you just want to lay your bike over on its left side.
    Unless you are extremely lucky and the old gasket comes off cleanly, the most tedious and time consuming part of this job will likely be removing the old gasket which will likely be stuck to the side cover and/or the crankcase.
    It is best to use a proper tool to remove the clutch basket and not just use a screwdriver and jam it between the narrow posts on the basket. These are easily broken and costly to replace. I do not have personal experience with aftermarket replacement clutches, but I have read good reviews about Barnett clutches. You may also want to consider replacing the stock springs with heavy duty springs.
    If you PM me your email address, I will send you some instructions that I prepared for removing a TW kickstarter which requires the removal of the clutch. These instructions also include several tips to ease reassembly.
    Here are examples of several tools for removing the clutch basket.
    This is a universal type of tool that will work for many different bikes.
    This is one that is specifically made for the TW.
    Mel, Lomax, LuvNot and 4 others like this.
    site:tw200forum.com
    6,019
    Make sure center bolt is adjust correctly. Red arrow.
    After market springs help. The short one is stock, the longer is aftermarket:
    Barnett Kevlar clutches are very good but cost about twice as much as a stock one. This guy accepted my offer of $70 so don't pay the asking price if you go this way. The kit includes new springs.
    YAMAHA BARNETT CLUTCH KIT TW200 TW 200 1978 - 2015 | eBay
    Use a torque wrench and don't over tighten the bolts or you will break the clutch basket.
    Ken, Mel, JerseyJeeper and 6 others like this.
    Oct 2012
    Blairsville GA
    18
    Thanx, one and awl!
    littletommy, JerseyJeeper and Ken like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    750
    I went ahead and ordered a set. Mine have 42000 miles on them. If these don't do better I'll go back to stock, they lasted since 1993. Thanks
    littletommy likes this.
  1. GPS, Headlight, general advice wanted
    By Zoart in forum Technical Help
    Last Post: 11-29-2014, 10:02 PM
  2. Clutch Switch WANTED
    By 50short in forum TW200 Classifieds
    Last Post: 04-23-2014, 07:19 AM
  3. Wanted: TW200 Clutch Basket
    By mrbracket in forum TW200 Classifieds
    Last Post: 01-19-2013, 06:27 PM
  4. Need advice on clutch behavior!
    By Gator in forum Technical Help
    Last Post: 09-06-2012, 04:34 PM
  5. Carb Soaking Advice Wanted
    By lorddaftbiker in forum Technical Help
    Last Post: 06-23-2011, 11:18 AM
